moony Posted June 14, 2013 Report Share Posted June 14, 2013 got some JOMS coilovers all round on my gti. There not the greatest, just shock and spring on back. My rear isnt even that low but because the shock is so soft its destroying my tyres. Can i buy harder shocks from anywhere?Thanks,Ben. 5 Quote Link to comment Share on other sites More sharing options...
Koop Posted June 15, 2013 Report Share Posted June 15, 2013 You could use spring assistors, Mitch had them on his arosa iirc Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted June 15, 2013 Report Share Posted June 15, 2013 The rear set is supposed to be like that.You don't want stiffer shocks, that'll just ruin the ride, you want stiffer springs. Quote Link to comment Share on other sites More sharing options...
Adam R4 Posted June 15, 2013 Report Share Posted June 15, 2013 Yeah runner a stiffer spring rate, I run 255lbs/inch on the rear Quote Link to comment Share on other sites More sharing options...
moony Posted June 16, 2013 Author Report Share Posted June 16, 2013 Yeah runner a stiffer spring rate, I run 255lbs/inch on the rear cheers mate, which make of spring have you got? can you order them seperate?Ben, Quote Link to comment Share on other sites More sharing options...
