Stevemaster Posted October 24, 2013 Report Share Posted October 24, 2013 awesome pic Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted October 24, 2013 Author Report Share Posted October 24, 2013 Picked these up from VW today 1 Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted October 24, 2013 Author Report Share Posted October 24, 2013 So got home from VW and gave the Lupo a clean then fitted the Cambridge rears.Much better with them on! Quote Link to comment Share on other sites More sharing options...
Silver! Posted October 24, 2013 Report Share Posted October 24, 2013 Looks good! I have a set of Cambridge rears; really need to finish de-tangoing them and swap them over.If you can find an Arosa in a breakers the have little covers which cover the rear light mounting screw heads.On the spacer front; I have a set of 10mm spacers which I keep planning on fitting on the front, but can never be arsed finding extended bolts; specifically locking bolts. Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted October 24, 2013 Author Report Share Posted October 24, 2013 Looks good! I have a set of Cambridge rears; really need to finish de-tangoing them and swap them over.If you can find an Arosa in a breakers the have little covers which cover the rear light mounting screw heads.On the spacer front; I have a set of 10mm spacers which I keep planning on fitting on the front, but can never be arsed finding extended bolts; specifically locking bolts.Cheers I was going to de-tango these before fitting but couldn't wait to get them on haha. I will do it one day.Thanks for the tip i will keep that in mind!I'm not sure what i could get away with on the front, i would like 10mm but think it would rub? :/ Quote Link to comment Share on other sites More sharing options...
Silver! Posted October 24, 2013 Report Share Posted October 24, 2013 I haven't actually tested mine, just by eye. I'm running 195\45 on my Bathursts though. Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted October 24, 2013 Author Report Share Posted October 24, 2013 I am running 195/45 too, maybe i could get away with it Quote Link to comment Share on other sites More sharing options...
Silver! Posted October 24, 2013 Report Share Posted October 24, 2013 I need to put my Bathursts back on, so will have a test fit of my 10mm spacers. Quote Link to comment Share on other sites More sharing options...
spy Posted October 24, 2013 Report Share Posted October 24, 2013 What do you mean by de-tangoing the cambridge lights - I can't see any orange on them ? Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted October 24, 2013 Author Report Share Posted October 24, 2013 What do you mean by de-tangoing the cambridge lights - I can't see any orange on them ?From the angle the picture has been taken at it is hard to see but in the grey strip in the middle there is an orange lens Quote Link to comment Share on other sites More sharing options...
spy Posted October 24, 2013 Report Share Posted October 24, 2013 (edited) OK Clayton, I see what you mean now. How are these de-tangoed ?I am thinking of getting a set as the car I may be buying needs one rear lens as the reverse part is cracked and letting water in.Seeing as I need 1, why not buy 2 Edited October 24, 2013 by spy Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted October 24, 2013 Author Report Share Posted October 24, 2013 I am not 100% on how to do it but i think most people smash the orange lens then get a small hoover attachment in the hole to remove all the little bits. Quote Link to comment Share on other sites More sharing options...
spy Posted October 24, 2013 Report Share Posted October 24, 2013 Interesting approach - how does that affect the turn signal ?Is the bulb white and the lens makes it yellow or is the bulb yellow and makes no difference ? Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted October 24, 2013 Author Report Share Posted October 24, 2013 The bulb that is in there is a clear one, so i am assuming you put an orange one in there after de-tangoing Quote Link to comment Share on other sites More sharing options...
Silver! Posted October 24, 2013 Report Share Posted October 24, 2013 You get orange bulbs with a silver coating so they don't show orange throught the lens, but flash orange when needed.http://dsa.ebay.co.uk/sch/i.html?_trksid=p2053587.m570.l1311.R1.TR8.TRC0.A0.Xsilver+ind&_nkw=silver+indicator+bulbs&_sacat=0&_from=R40http://www.amazon.co.uk/s/?ie=UTF8&keywords=silvertech&tag=googhydr-21&index=aps&hvadid=28709745368&hvpos=1t3&hvexid=&hvnetw=g&hvrand=5780407341406305888&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_58ax16w0wu_b#/ref=nb_sb_ss_i_0_10?url=search-alias%3Daps&field-keywords=silver+indicator+bulbs&sprefix=silver+ind%2Caps%2C753&rh=i%3Aaps%2Ck%3Asilver+indicator+bulbsI have detangod one with a pair of snips and long noosed pliers. Quote Link to comment Share on other sites More sharing options...
spy Posted October 24, 2013 Report Share Posted October 24, 2013 Thanks Silver. I know the ones you mean. I bought a set a few moths ago for my Porsche so as to avoid the orange bulb showing through.Which as the correct ones (pins, voltage and wattage wise) for the GTi ? Quote Link to comment Share on other sites More sharing options...
Silver! Posted October 24, 2013 Report Share Posted October 24, 2013 ...bulb no. 382 for the rear indicatorshttp://www.halfords.com/webapp/wcs/stores/servlet/categorydisplay_storeId_10001_catalogId_10151_categoryId_165538_langId_-1 Quote Link to comment Share on other sites More sharing options...
spy Posted October 24, 2013 Report Share Posted October 24, 2013 ...bulb no. 382 for the rear indicatorshttp://www.halfords.com/webapp/wcs/stores/servlet/categorydisplay_storeId_10001_catalogId_10151_categoryId_165538_langId_-1Thx, good man Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted October 27, 2013 Author Report Share Posted October 27, 2013 Just a little update, finally sorted out my door check straps. Easy fix and the best thing i have done so far! Also i was changing a number plate bulb a week ago and broke a clip on the unit so decided to get some LED units, much better than your usual LED bulb, so bright! Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted October 31, 2013 Author Report Share Posted October 31, 2013 My door handle covers were looking scratched and tatty as they do in most Lupo's. So i decided to plastidip them, looks so much better now. Before and after pic here - Quote Link to comment Share on other sites More sharing options...
Danyutz Posted November 2, 2013 Report Share Posted November 2, 2013 Sure looks great! 1 Quote Link to comment Share on other sites More sharing options...
666DUB Posted November 2, 2013 Report Share Posted November 2, 2013 Clayton, that is one nice Lupo! 1 Quote Link to comment Share on other sites More sharing options...
Benjeee19 Posted November 2, 2013 Report Share Posted November 2, 2013 Looking good mate have you thought about doing the exhaust mod using a bolt through the plate into the wheel well area to raise it up? Quote Link to comment Share on other sites More sharing options...
CLAYTONJONES Posted November 2, 2013 Author Report Share Posted November 2, 2013 Looking good mate have you thought about doing the exhaust mod using a bolt through the plate into the wheel well area to raise it up?Cheers mate, i have thought about it a few times but i'm more than likely going to get a new exhaust soon anyway. Any suggestion to which exhaust? Quote Link to comment Share on other sites More sharing options...
Mattz341 Posted November 3, 2013 Report Share Posted November 3, 2013 Beautiful lupo dude! Just a quick question, is that colour standard? Or has it been resprayed? If it has been resprayed then was the boot and engine bay done too? Apologies if there's photos of the engine bay or boot that I've missed!! Quote Link to comment Share on other sites More sharing options...
