AlexFox Posted April 21, 2013 Report Share Posted April 21, 2013 How do you smooth rear lights and do you need a machine buffer or can you do it by hand Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted April 21, 2013 Report Share Posted April 21, 2013 Sand the bits down.Use progressively finer grades.Use a polish to get a shiny finish.You don't need a machine, it'll be quicker but, you're never going to burn/melt the plastic by hand and if you don't know your way around a machine it is a possibility.Same process used for making any thing smooth really. Quote Link to comment Share on other sites More sharing options...
AlexFox Posted April 21, 2013 Author Report Share Posted April 21, 2013 Okay cheers pal i just didnt know if if it would work by hand but nar i know and can you just use megs polish the polish them up and wat grade sand paper Cheers Alex Quote Link to comment Share on other sites More sharing options...
Deadmetal Posted April 21, 2013 Report Share Posted April 21, 2013 Start with a rough one, to sand them flat and then work up to the finest you can find.2000 grit wet and dry seems to work for me.Any car polish will work, if you've got something like paint renovator, use that first, as it's not as fine as polish.Use the car polish last. Quote Link to comment Share on other sites More sharing options...
Skezza Posted April 21, 2013 Report Share Posted April 21, 2013 Can this cause an MOT fail, because the spread of light won't be as great as when they are frosted? Quote Link to comment Share on other sites More sharing options...
Pete Posted April 21, 2013 Report Share Posted April 21, 2013 No. Quote Link to comment Share on other sites More sharing options...
Fretwell Posted April 21, 2013 Report Share Posted April 21, 2013 Can this cause an MOT fail, because the spread of light won't be as great as when they are frosted? What ? He's removing the markings from the making process and some small numbers ? How would it cause a failure Quote Link to comment Share on other sites More sharing options...
Skezza Posted April 21, 2013 Report Share Posted April 21, 2013 What ? He's removing the markings from the making process and some small numbers ? How would it cause a failureI assumed he was smoothing off the frosting from the inside, which would make them transparent as opposed to translucent. I believe this is possible by smoothing off the inside which is rough, thus creating the effect that the light from the bulb is coming straight through. The reason I asked if it was an MOT fail is because as of about 2 years ago, any modification that significantly reduces light emitted from a headlight or rear light can be deemed unsafe and as such an MOT fail. The reason it's frosted is to allow the light to spread, allowing a much wider visibility. Just a question Quote Link to comment Share on other sites More sharing options...
vince172 Posted April 22, 2013 Report Share Posted April 22, 2013 what he is referring to (i believe) are the manufacturers markings etc which are raised off the outer lense surface. he wants to smooth them out/remove them. a mod I've seen quite a few times. your 'average' mot inspector would never think of checking these or would probably never notice. on a legality point. i would say it to be illegal as you would be removing the E markings etc. but hey, what 'normo' would ever notice! i want to do this to mine soon! Quote Link to comment Share on other sites More sharing options...
Fretwell Posted April 23, 2013 Report Share Posted April 23, 2013 I assumed he was smoothing off the frosting from the inside, which would make them transparent as opposed to translucent. I believe this is possible by smoothing off the inside which is rough, thus creating the effect that the light from the bulb is coming straight through. The reason I asked if it was an MOT fail is because as of about 2 years ago, any modification that significantly reduces light emitted from a headlight or rear light can be deemed unsafe and as such an MOT fail. The reason it's frosted is to allow the light to spread, allowing a much wider visibility. Just a question Didn't realise what you meant dude! I knew what the post owner was on about . Not heard about what you said being done before Quote Link to comment Share on other sites More sharing options...
