colinsimons Posted February 11, 2013 Report Share Posted February 11, 2013 Should be a simple job,I would have hoped. Have removed the two bolts but unable to lift off the filter box because there are various rubber pipes attached to it preventing this. I see that the filter box is screwed together but the screws are underneath and impossible to access without lifting off the filter box and turn it over. Your help and advise is required here. Many thanksOBS Quote Link to comment Share on other sites More sharing options...
Al3xTee Posted February 11, 2013 Report Share Posted February 11, 2013 (edited) There should one on the left leading to other parts of your engine, and one of the right leading to your rocker cover, they both easily pull off and a little persuasion at the back of the filter box (pull upwards) will get it off. Hope this helps Edited February 11, 2013 by Arosa.Al 1 Quote Link to comment Share on other sites More sharing options...
colinsimons Posted February 11, 2013 Author Report Share Posted February 11, 2013 That's fantastic info. Most helpful. I'll get that done asap. What spark plugs you've fitted? I've ordered NGK 30 pzfr5d 11 s from eBay. Halfords wanted £45 for theirs. Where do you buy your service parts? Ever found a workshop manual? Thanks OBS Quote Link to comment Share on other sites More sharing options...
GTIChris Posted February 11, 2013 Report Share Posted February 11, 2013 There is no manual as such, a Polo one is the nearest you'll get as they share a lot of parts. 1 Quote Link to comment Share on other sites More sharing options...
Al3xTee Posted February 11, 2013 Report Share Posted February 11, 2013 No problem I can't remember at all what spark plugs I've got, I know they were expensive though! I have a local motor spares shop that's does everything I need for a good service. The Polo 6N manual is probably the closest, I may be corrected 1 Quote Link to comment Share on other sites More sharing options...
colinsimons Posted February 12, 2013 Author Report Share Posted February 12, 2013 Again Thank you both for your help here! Quote Link to comment Share on other sites More sharing options...
