TArosa Posted January 25, 2013 Report Share Posted January 25, 2013 Just bought a mk2 arosa 1.0s "03" of a mate and it has remote locking key fob OEM; the fob LED lights up when you click either buttons but the car doesn't lock or unlock. Has anyone got any suggestions, much appreciated. Rob Quote Link to comment Share on other sites More sharing options...
Pete91 Posted January 25, 2013 Report Share Posted January 25, 2013 Try re-learning them through vagcom (if you have vagcom of course). There's a way you can do it manually but I've never done it myself. If you get hold of someone with vagcom it's reeeally easy to do. Quote Link to comment Share on other sites More sharing options...
TArosa Posted January 25, 2013 Author Report Share Posted January 25, 2013 i dont uinfortunetly but is this the process you were refering to?..."First off, you require 2 keys to do it without a diag tool or your wasting your time.1. Put 1 key in the ignition and turn the ignition on. (this way the car knows its got a known key in it and is happy)2. Close all the doors and boot. (The car hates getting a chill and you need to keep it happy)3. Put your other key in the drivers door and manually lock the car. (Remember the car is happy as it has a known key in the ignition and now you have a second key and manually locked it, it still knows its safe and will accept a new remote signal)4. Press the button on the remote and you will hear a 'chirp' of acceptance. (This is the car letting you know its delighted to have another remote signal stored)5. Manually unlock the car. (So it knows not to accept any other signals)6.Turn off the ignition remove the key, close the door and confirm operation of the remote.7. Your now as happy as the car "cheers for the advice on what to look for though pete ... i would have started ripping thing apart looking for problems being a hand fisted fitter ha Quote Link to comment Share on other sites More sharing options...
Skezza Posted January 26, 2013 Report Share Posted January 26, 2013 I can't remember is it VAGCOM or VAG Tacho that allows you to view the number of paired remotes? The max is 4 I believe. Quote Link to comment Share on other sites More sharing options...
Pete91 Posted January 26, 2013 Report Share Posted January 26, 2013 Yeah that's the one mate and no worries Yeah skezza I'm pretty sure it's 4 too. Quote Link to comment Share on other sites More sharing options...
TArosa Posted January 27, 2013 Author Report Share Posted January 27, 2013 had a go at this and .. nowt :/ any suggestion or just see if i can find someone with vagcom? Quote Link to comment Share on other sites More sharing options...
Pete91 Posted January 27, 2013 Report Share Posted January 27, 2013 Yeah I would probably try get a go on vagcom. A garage should be able to help you out Quote Link to comment Share on other sites More sharing options...
TArosa Posted January 27, 2013 Author Report Share Posted January 27, 2013 nee bother, will give it a go cheers Quote Link to comment Share on other sites More sharing options...
TArosa Posted March 12, 2013 Author Report Share Posted March 12, 2013 had this plugged into vagcom a month or soo ago following this and the car wouldnt recognise the key; the lad said it might be the com fort module??..another point is that the auto-lock & unlock was turned on but only the auto-lock worked, could this be related as i know the module controls windows and locking.also if i was to need a new CCM what do i need to be looking for? certain amount of pins in the plug? or does it have to be a dealer part?thanks Quote Link to comment Share on other sites More sharing options...
TArosa Posted March 13, 2013 Author Report Share Posted March 13, 2013 Anyone? any advice would be greatly appreciated Quote Link to comment Share on other sites More sharing options...
electricracer Posted March 13, 2013 Report Share Posted March 13, 2013 the comfort module is behind the fuse box, you can just about get it out without removing the dash, it is a black box with three large plugs going into it about the size of two fag packets(ish) if you get it out you will need the part no from it, i think most lupos/arosas have the same part no just letters on the end different you will need the exact same one, i do have one here if the part nos match £30 posted i will find my part no later Quote Link to comment Share on other sites More sharing options...
TArosa Posted March 13, 2013 Author Report Share Posted March 13, 2013 cheers man, will hopefully get around to having a look at the weekend Quote Link to comment Share on other sites More sharing options...
