Rear light HELP!!!!!!!
adambaron1
Ok well ive tried to change my arosa lights to lupo lights and me being special i cannot get the pins out! I have read through the other threads and i still dont get it?! How do you acctually get the pins out the holder so i can change them round for the lupo lights to work properly! The help would be massivley appreciated!
If you open up the connector you can push the pins out with a teeny screwdriver. It's a bugger alright.
Surely it's easier to just buy the proper tool ?
Alternatively you're not thinking outside the box and just using a teeny set of small tweasers.
The way I've seen it done is open the plug up & push them out from the inside.
What's the 'proper tool' then Rich?
It's a tool which has two very thin slivers of metal and it pushes the clips in and you can then pull the wire out of the plastic housing with the crimp still attached.
That's why you can just use some small tweezers to replicate it.
Are you saying he's not special?
Have you got some Lupo rear lights? I've got a set I'm not going to use and I would be happy to be rid of them and reclaim the space.
If the classifieds were worth it I would advertise them there.
