fatttty Posted January 18, 2014 Author Report Share Posted January 18, 2014 How's the FRP? Good mate, getting there slowly. Got a fair bit done over the past month.Had the majority of the front end parts blasted. They used a mixture of soda, vapor and glass depending on the material and the finish that I was going to apply. The subframe and wishbones were glass'd so the powdercoat would stick better, the torque link and alloy parts were vapor blasted and the manifold and steering rack were soda blasted.Parts came back from powdercoat, had the subframe and wishbones done in an OEM satin black and the ARB in anthracite grey to break things up a little. Also had the steering knuckle joints done in the grey to match.Parts that weren't powdercoated were given a coat of hiugh temp silber paint. Did the torque link, gear box mount and a bracket for the back of the engine.Next up I had the front wheel bearings pressed in.And the powerflex wishbone bushes front and rear.Finally I have split the drive shafts down, removed CV joints and boots (got new ones to rebuild)More to come Alex Quote Link to comment Share on other sites More sharing options...
nellytheelephant Posted January 19, 2014 Report Share Posted January 19, 2014 makes me want a ford Quote Link to comment Share on other sites More sharing options...
fatttty Posted January 20, 2014 Author Report Share Posted January 20, 2014 makes me want a fordCheers Gave my manifold a couple of coats of high temp enamel paint. Still needs another coat but pretty happy with it 1 Quote Link to comment Share on other sites More sharing options...
jpsh120 Posted January 20, 2014 Report Share Posted January 20, 2014 That high temp is almost certain to flake and burn off, unless you've managed to find some that is any good. After all your hard work, it would be worth you getting it ceramic coated, looks better and it lasts! Quote Link to comment Share on other sites More sharing options...
fatttty Posted January 20, 2014 Author Report Share Posted January 20, 2014 That high temp is almost certain to flake and burn off, unless you've managed to find some that is any good. After all your hard work, it would be worth you getting it ceramic coated, looks better and it lasts!Ceramic is the method I wanted to use, just too expensive. I had this paint on the lower section of the mani for 8 months with no signs of wear so should be fine, will need to be careful refitting it though Quote Link to comment Share on other sites More sharing options...
sj2112 Posted January 20, 2014 Report Share Posted January 20, 2014 Doesn't drive it enough to worry about it flaking off ;-) Quote Link to comment Share on other sites More sharing options...
fatttty Posted January 21, 2014 Author Report Share Posted January 21, 2014 Doesn't drive it enough to worry about it flaking off ;-)Lol true that is a good point haha! Quote Link to comment Share on other sites More sharing options...
fatttty Posted January 22, 2014 Author Report Share Posted January 22, 2014 So I picked my bolts and parts from the electroplaters yesterday. They did a top job as normal. I had spent about 3 hours cleaning them to ensure they would plate well and the finish would be good. I had two batches done one in silver zinc (subframe, wishbone bolts etc) and another in yellow passivate for the smaller items, I like anything that's painted silver to be bolted with gold bolts to get a nice contrast and help break things up... I'm odd, I know! Before - And after - Quote Link to comment Share on other sites More sharing options...
fatttty Posted January 30, 2014 Author Report Share Posted January 30, 2014 Picked up some more parts from the soda blasters last night, I think this is pretty much the last of my parts that needed stripping. Had the drive shafts, intermediate shaft, ABS rings, and a few power steering brackets done. Also had my hubs back from being chemiblacked, opted for this finish as it has similar characteristics to powdercoat but you don't need to worry about masking off the spine or bearing faces as the finish does not add nay thickness to the surface material. Very OEM looking- And lastly I had the final part I needed to rebuild the driveshafts, the intermediate drive shaft bearing. Genuine Ford, found one on eBay brand new for a 'reasonable' price:) Rebuild my hubs and steering knuckles last night. Really pleased with them, they look as good as new Quote Link to comment Share on other sites More sharing options...
Piers Posted January 30, 2014 Report Share Posted January 30, 2014 Unreal Alex... Quote Link to comment Share on other sites More sharing options...
dubsy Posted January 30, 2014 Report Share Posted January 30, 2014 awesome as always alex Quote Link to comment Share on other sites More sharing options...
fatttty Posted January 30, 2014 Author Report Share Posted January 30, 2014 Unreal Alex... awesome as always alex Cheers guys! Much more to come Alex Quote Link to comment Share on other sites More sharing options...
fatttty Posted January 31, 2014 Author Report Share Posted January 31, 2014 Small update, I picked up my drive shafts from the powder coaters yesterday. Really pleased with them they did a great job as expected. For those that don't know the FRP had one blue drive shaft (for the drivers / off side) and one black (for the passenger / near side) not sure why but that's how they came so wanting to keep things original I did the same. Drive shafts; one blue, one satin black- Intermediate shaft in satin black- And a few power steering pipework brackets I had done- Alex Quote Link to comment Share on other sites More sharing options...
sj2112 Posted January 31, 2014 Report Share Posted January 31, 2014 Jesus this is just insanely good!! Quote Link to comment Share on other sites More sharing options...
Lupo-Joe Posted January 31, 2014 Report Share Posted January 31, 2014 It's like art work Quote Link to comment Share on other sites More sharing options...
fatttty Posted February 1, 2014 Author Report Share Posted February 1, 2014 Jesus this is just insanely good!!It's like art work Lol cheers guys, its very nearly ready to go back together still a few weeks off as I dont want to rush anything but things are coming together now Alex Quote Link to comment Share on other sites More sharing options...
fatttty Posted February 1, 2014 Author Report Share Posted February 1, 2014 Today I rebuilt my drive shafts, really pleased with how they came out. Fitted new CV joints, boots and clips all round.Also fitted the big bearing to the intermediate drive shaft and got it fitted back to the short shaft ready to go back on the car Quote Link to comment Share on other sites More sharing options...
Kent Posted February 2, 2014 Report Share Posted February 2, 2014 I saw another FRP on the road last week surprisingly as don't think I've seen one before.. not knowing anyway.This is incredible, love the attention to detail & the touches to keep with the original styling.. honestly amazing! Quote Link to comment Share on other sites More sharing options...
fatttty Posted February 2, 2014 Author Report Share Posted February 2, 2014 I saw another FRP on the road last week surprisingly as don't think I've seen one before.. not knowing anyway.This is incredible, love the attention to detail & the touches to keep with the original styling.. honestly amazing!Cheers Ross they are rare to see on the road I've not seen one for ages. Can't wait to get mine back out on the roads in a few months time! Quote Link to comment Share on other sites More sharing options...
Kent Posted February 2, 2014 Report Share Posted February 2, 2014 I'd be scared to drive it haha!! It's a work of art Quote Link to comment Share on other sites More sharing options...
fatttty Posted February 2, 2014 Author Report Share Posted February 2, 2014 I'd be scared to drive it haha!! It's a work of artLol nah I drive it and enjoy it. Only in the dry, can't get wet... It is a ford remember lol! Quote Link to comment Share on other sites More sharing options...
Huw Pugh Posted February 2, 2014 Report Share Posted February 2, 2014 This is on another level! Quote Link to comment Share on other sites More sharing options...
fatttty Posted February 2, 2014 Author Report Share Posted February 2, 2014 This is on another level! Cheers Huw, it's gone a lot further than I'd ever planned. I'm enjoying it though and learning new stuff as I go Quote Link to comment Share on other sites More sharing options...
fatttty Posted February 7, 2014 Author Report Share Posted February 7, 2014 Little update Finished the steering rack, got all the pipework refitted, fitted new rubber sleeves and clips and got it mounted back on to the front subframe. Also fitted the ARB to the subframe, fitted with new powerflex bushes and new brackets and bolts. So everything is fitted to the subframe and basically it is ready to lift back into place, a job for the weekend hopefully. Before I piece it all back together again I couldn't leave the back of the engine filthy so I gave it a good degreasing and clean with a variety of small brushes, and a quick coat of enamel engine paint, it needs a second coat but you get the idea Alex Quote Link to comment Share on other sites More sharing options...
fatttty Posted February 11, 2014 Author Report Share Posted February 11, 2014 Put my gear linkage back together today, one less job to do. Linkages were painted gold and fitted with new bolts, also got a new sponge insulator thing too. So I managed to put the majority of the car back together today. Didn't take too many photos during but got a fair few once it was done. Started by fitting the new ABS sensors to the hubs- Got the last parts from out of my old room (car part storage room!) and checked what bolts they need. Torque link bracket for the back of the gearbox- Bracket that holds the manifold heat shield to the back of the engine- Fitted those- Then fitted drivesahfts, knuckle joints and hubs- Fitted the wishbones back on the subframe so it was basically ready to lift into place- Forgot to bolt the steering column so had to take it off again to do this grrrrr! Subframe fitted- Drop links done- And finally calipers and discs back on- Later in the week I'll torque up the hub bolts, double check everything and get the car lifted higher to make fitting the manifold easier. That's all for now Alex Quote Link to comment Share on other sites More sharing options...
