lupo1.0SEyellow Posted October 10, 2012 Report Share Posted October 10, 2012 my car seems to be drinking loads of coolant.Can't see any leaks, any ideas? Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted October 10, 2012 Report Share Posted October 10, 2012 Any white deposits in the engine bay?HGF is very rare in Lupos, so more that likely to be leaking Quote Link to comment Share on other sites More sharing options...
lupo1.0SEyellow Posted October 10, 2012 Author Report Share Posted October 10, 2012 Just anywhere in the engine bay? Ill have a look, if not ill put in somewhere for them to locate the leak Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted October 10, 2012 Report Share Posted October 10, 2012 At the ends of hoses and the rad.Check around the water pump too - when was this last changed? Quote Link to comment Share on other sites More sharing options...
lupo1.0SEyellow Posted October 10, 2012 Author Report Share Posted October 10, 2012 Never changed. The rad? Quote Link to comment Share on other sites More sharing options...
m1cr08472 Posted October 11, 2012 Report Share Posted October 11, 2012 Check for steam coming out the exhaust, bear in mind sometimes condensation builds up in the exhaust over night and blows out steam for a while after you start the car but if its always blowing steam there must be water getting into the exhaust from the cylinders.Check the dip stick for small deposits of water and mayo on the top of the stick and oil cap.My headgaskets gone and I get a lot of oil building up in the top of the header tank and its starting to lose more and more water as the cold weather sets in. Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted October 11, 2012 Report Share Posted October 11, 2012 The water pump has never been changed? What about the belts? Quote Link to comment Share on other sites More sharing options...
lupo1.0SEyellow Posted October 12, 2012 Author Report Share Posted October 12, 2012 Had it in today, turns out there is a leak in the radiator.As for belts defcon5 i've done the cam belt but thats it, nothing needs doing as it stands.Cheers for your help lads! Quote Link to comment Share on other sites More sharing options...
