Tigz™ Posted April 20, 2005 Report Share Posted April 20, 2005 (edited) Photos and Specs Only Please.A photo only is fine, but it would be good to answer all the common questions, in this post.When writing specs, please include rms ratings of your amps, and any extra goodies you have helping it along. If you have a link to your products on line post it and I'll make it look pretty for you if you don't know how. I will host up to 2 photos for anyone without the use of anywhere.TigzIf it is possible could you please resize them to a maximum 800x600 so they will fit in the Page alright.If you don't know how, I can do it, but I would love you more if I didn't have to :wink:Please no Spam.Drop me a pm if you have any comments/queries.Discussion Thread please use this. Edited December 15, 2005 by Tigz Quote Link to comment Share on other sites More sharing options...
tshirt2k Posted May 12, 2005 Report Share Posted May 12, 2005 (edited) >Tshirt2k's ICE< Clarion headunit DXZ848RMC Infinity 65.5 Cs components in MDF mountings 90 WRMS Crystal Comp 10 in Custom made 0.9 cuft sealed Fibreglass enclosureRockford fosgate P8004 amp 2 x 100 WRMS & 1 X 400 WRMS Info on Rockford fosgate amp can be found Here Edited November 13, 2008 by Tigz 7 Quote Link to comment Share on other sites More sharing options...
FunkyMunky Posted June 5, 2005 Report Share Posted June 5, 2005 Sony F7700 headunit (i know i know, shoot me)4 Alpine Type S 5x7" Components, unfortunately powered by the headunit1 Kenwood KAC-PS811D Amp giving 1 x 800rms at 2ohm2 JL W3v2-D2 subs powered by the Kenwood ampDynamat Extreme on the boot floor and wheel archesDynamat Original surrounding each component Quote Link to comment Share on other sites More sharing options...
Steffro Posted June 21, 2006 Report Share Posted June 21, 2006 (edited) Thought id add my ICE here, not a lupo but shows what can be done with a small amount of space-JVC Headunit with iPod interface4 Channel Rockford Fosgate Amp, giving Kenwood components 65wrms each and a JBL 8" sub 250wrms.Flashing tape, eDead, Second Skin as sound deadening/proofing.Still plenty of boot space left for stuff. Edited November 13, 2008 by Tigz Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted August 22, 2006 Author Report Share Posted August 22, 2006 hi guy's got the gti on sunday, so set about mounting the sub and what not.system:vibe black hex 6.5 speakers Specifications*BlackHex 6 Type Co-axial Configuration 2-way Speaker Size 6.5" (165mm) RMS Power 100w Peak Power 300w Sensitivity 87dB Frequency Response 40 - 25,000Hz Impedance 4ohm Mounting Depth 76mm Mounting Diameter 140mm these really thump, had these in my leon, and put them into my home cinemas speakers.then the ampvibe black box 1Specifications*BLACKBOX I Height 50mm Width 224mm Depth 177mm RMS Out @4ohm 2 x 70w RMS Out @2ohm 2 x 100w RMS Out @4ohm 1 x 200w SNR 100dB Frequency Response 20 - 20,000Hz THD 0.05% Crossover Type LP/HP/Flat Crossover Range 50 - 5,500Hz Crossover Slope 12dB Bass Enhance(variable @ 45Hz) 18dB Max Power 400W kenwood 12" w3009 subSize 12 -inch Impedance 4 ohms Cone Material Pearl mica IMPP Surround Material Urethane foam Sealed Box Volume (cubic feet) 0.8 - 1.5 Ported Box Volume (cubic feet) 1 - 2 Port diameter (inches) 3 Port length (inches) 7 Sensitivity 93dB Frequency Response 25 - 0.8k Hz RMS Power Range (Watts) 35-400 Peak Power Handling (Watts) 800 Top Mount Depth (inches) 5 5/16 Bottom Mount Depth (inches) 6 1/8 Cutout Diameter or Length (inches) 11 Vas (liters) 63.93 Fs (Hz) 32 Qts 0.42 Xmax (millimeters) 8 Parts Warranty 1 Year Labor Warranty 1 Year cross over just to run the sub gives more tuning, cant remember the make.head unit sony cdx-ra650 because it has a sub out, and matches the factory dialsDRIVE-S HX 4 x 52 W S-MOSFET power output MP3 / WMA / ATRAC playback ID3 Tag display Full Motion Dot Matrix FL Display Motorised Motion Blade-plus (Synchronised Flip Front Panel) 24-bit DAC (Digital / Analog Converter) DSO / EQ7 Parametric EQ3 (3 Band Equalizer) 2 Pre-outs + Dedicated Subwoofer Output BBE MP Digital - High Definition Sound WALKMAN / CD Changer Control Ready IR card remote RM-X151 supplied Detachable front panel here are some pics of the sub, i got the cutting diagram from this sitehttp://www.subwoofertools.com/forum/ported...mp;Fs=&CE=0its tuned to 45 hertz Quote Link to comment Share on other sites More sharing options...
diddy Posted January 27, 2007 Report Share Posted January 27, 2007 nearly a full kenwood systemkenwood head unitipod linkkenwood 6x9'skenwood 1800w amp (with remote mounted on shelf)kenwood 12" subalpine component door speakers n tweetersi made the box and shelflet me know what you think? Quote Link to comment Share on other sites More sharing options...
Tallika_Fan Posted March 29, 2007 Report Share Posted March 29, 2007 (edited) Thought i'd add mine upWhat i had before:What i have now, needs finishing though:Finished it....for now at least.And yet more installments.... Edited January 7, 2009 by Tallika_Fan Quote Link to comment Share on other sites More sharing options...
SC02 FFF Posted May 7, 2008 Report Share Posted May 7, 2008 (edited) Components: Rainbow Kick Components @ 100RMS 4ohm RE MX tunned to 30Hz 1500RMS @ 1ohm, (possibly getting a more powerful amp ) Subs been reconned atmProbably around 120 DB's need to get testedupdate of mine 12' RE MX Dual coil with 2000.RMS SPL Dynamics + 12' RE MX 1OHM -Powerbass & Kenwood amps + 275 Rainbow kick components 400.RMS plus-Uprating alternator to 150amnps. also adding something for mid bass @ 350.RMS-optima yellow top Edited November 13, 2008 by Tigz 1 Quote Link to comment Share on other sites More sharing options...
scoobydoo Posted June 4, 2008 Report Share Posted June 4, 2008 (edited) minepioneer headunit - deh-p3600mpbalpine spr 176a components - 50w RMS with plenty of sound deadining in the doors ----> powered by alpine MRP-T222 two channel amp - 50w per channel at 4 ohmshad alpine type r 1221 12 inch sub (300w RMS) now pioneer tsw 3004 spl (1000w RMS according to google dont believe that for a second though lol) ----> powered by alpine MRD-M605 600w RMS single channel running at two ohms. Edited June 23, 2008 by scoobydoo Quote Link to comment Share on other sites More sharing options...
robgti Posted June 24, 2008 Report Share Posted June 24, 2008 (edited) heres my install in my gti(now has two 10"s instead of the one you see in the pics)Clarion: VRX928RVD DVD HeadunitPioneer: TS-E176C - 17cm Components front and rearsPowered byPioneer: GM-6300F Amplifier - 4 channel ampPioneer: TS-W257DVC - 10" 1200W subwoofer Dual Voice Coil Powered byPioneer: GM-7300M Amplifier - MONO BASS AMPTwo fuse blocks and a 1.5 Farad Power CapacitorPhoenix Gold Bass Cubesoon to have another set of components in the boot lidheres a picture someone took from GTI inters Edited June 24, 2008 by robgti Quote Link to comment Share on other sites More sharing options...
Alex_225 Posted July 10, 2008 Report Share Posted July 10, 2008 I don't have any ICE in my Lupo as yet, but got a few bits set up in my Megane. Its still running the standard six speakers but also runnning a pair of Pioneer 6x9s, Legacy Amp and 12" Vibe sub all running from a Pioneer head unit. This is the headunit the Lupo will be inherting though - And this is the new head unit I've got sitting waiting to go in the Megane - Quote Link to comment Share on other sites More sharing options...
little rich Posted September 21, 2008 Report Share Posted September 21, 2008 (edited) alright all, thought id stick mine up, got it db tested at trax by DB drag at 145.5 db @ 41hzalpine 9866r head unitsun down 2500 amp, starsound 2000.4 4 channel amp starsound ssk 165 components oz audio matrix elite 15" sub, x2 2x yellow top batteries clifford arrow 5.1 alarm central and remote central locking being installed, custom box, HU 2x yellow topscomponents (new tweaters mounted in the normal place)subscustom boxampsretrimed and finished with the odd monkey and banana thrown in!thanks alot, hope you like, rich Edited September 21, 2008 by little rich 1 Quote Link to comment Share on other sites More sharing options...
seanyb Posted October 19, 2008 Report Share Posted October 19, 2008 quick look at my install.Consists of:mb quartz mq 218.61q componentsboston acoustics G2 8" subwooferaudison spx2 amplifiertamagotchy 7" screen dvd headunit (has alpine guts!)has a false floor in the boot which also has the spare wheel still in. sound deadening in the boot and in the doors and throughout the car under the carpet with all the wires running down the centre of the car.all in all sounds really nice fancy some more bass tho listen to alot of electro, house, dnb and jungle!Pics!..thanks for looking Quote Link to comment Share on other sites More sharing options...
stevie_wonder Posted November 12, 2008 Report Share Posted November 12, 2008 this is my new sound system its a top piece of kit Audiobahn A2300HCT 2400watt RMS peak power 4800watt this has been reduced to 2 x1200 rms so it doesnt blow the subs 2x Audiobahn subs AW1206T 2x1100watt RMS peak power 2x2200watt Quote Link to comment Share on other sites More sharing options...
vpolo Posted November 13, 2008 Report Share Posted November 13, 2008 heres mine before i trim it Quote Link to comment Share on other sites More sharing options...
willooon Posted December 24, 2008 Report Share Posted December 24, 2008 the speakers, rear 240 watt x 2, tweeters x 4, shelf speakers 300w x2, front door speakers 240w x 2the sub (2000w)the custom box and amp (2600w)hope you like! Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted December 24, 2008 Author Report Share Posted December 24, 2008 Very nice. Quote Link to comment Share on other sites More sharing options...
vpolo Posted December 24, 2008 Report Share Posted December 24, 2008 finished Quote Link to comment Share on other sites More sharing options...
seanyb Posted December 24, 2008 Report Share Posted December 24, 2008 Very nice.cheers bud, not as beefy as i would like but nice sound and looks the part.just looking to better my equipment next year love the ice you can squeeze into a lupo good challenge. Quote Link to comment Share on other sites More sharing options...
vpolo Posted February 8, 2009 Report Share Posted February 8, 2009 finaly boot build finished Quote Link to comment Share on other sites More sharing options...
SC02 FFF Posted February 8, 2009 Report Share Posted February 8, 2009 Quote Link to comment Share on other sites More sharing options...
JamieB Posted May 14, 2009 Report Share Posted May 14, 2009 Ive Got A 2000W Amp With 2x 12" JBL Speakers... JUST Fits Into The Arosa And No More... Shakes The Whole Car =L Quote Link to comment Share on other sites More sharing options...
dubsy Posted May 14, 2009 Report Share Posted May 14, 2009 Quote Link to comment Share on other sites More sharing options...
SC02 FFF Posted May 14, 2009 Report Share Posted May 14, 2009 (edited) sick bro it really is! btl's ftw details though mate? Edited May 14, 2009 by SC02 FFF Quote Link to comment Share on other sites More sharing options...
dubsy Posted May 15, 2009 Report Share Posted May 15, 2009 its a sql set up andy so the fi q dual 2 is running sealed but is being given 1200 at 1 ohm from a DLS A3 its no way as lond as your blt but the sq of the system has to be heard to be appreciated i was gonna compete in emma this year but there are so many vw shows im commited to this year i just couldnt juggle the two, as for the FI one word awesome Quote Link to comment Share on other sites More sharing options...
