MissCooks Posted September 11, 2012 Report Share Posted September 11, 2012 I've lost my main car key and have to now use my spare. The central locking isn't working at all and i can't lock the car manually.Is there something i need to do to make it work? i've tried changing the key battery but this doesn't solve the problem.Can anyone help me?Thanks, T Quote Link to comment Share on other sites More sharing options...
James827 Posted September 11, 2012 Report Share Posted September 11, 2012 It needs reprogramming.and you would need two keys to do that i think. so unless you head to the stealer's your going to be doing it the ol' fashioned way. Quote Link to comment Share on other sites More sharing options...
MissCooks Posted September 12, 2012 Author Report Share Posted September 12, 2012 Does anyone know how to reprogramme it? - It doesn't even work the 'ol'fashioned' way!If anyone has any advice, i'd be most grateful! Quote Link to comment Share on other sites More sharing options...
MissCooks Posted September 13, 2012 Author Report Share Posted September 13, 2012 Anyone? Quote Link to comment Share on other sites More sharing options...
forsh21 Posted September 15, 2012 Report Share Posted September 15, 2012 Look on the how to section (flip key) Quote Link to comment Share on other sites More sharing options...
MissCooks Posted September 24, 2012 Author Report Share Posted September 24, 2012 I couldn't find a section on 'how to' to help with this so any suggestions still welcome! Quote Link to comment Share on other sites More sharing options...
Pete91 Posted September 24, 2012 Report Share Posted September 24, 2012 Do you have/know someone who has vagcom? Quote Link to comment Share on other sites More sharing options...
Pete91 Posted September 24, 2012 Report Share Posted September 24, 2012 Does it lock if you use the key in the door? Quote Link to comment Share on other sites More sharing options...
MissCooks Posted September 25, 2012 Author Report Share Posted September 25, 2012 Does it lock if you use the key in the door?No doesn't lock if i use the key in the door. And i'm not sure what a vagcom is? Quote Link to comment Share on other sites More sharing options...
Pete91 Posted September 25, 2012 Report Share Posted September 25, 2012 Hmm i can't think of a reason for it not to work in the lock other than it's not the right key or a nackered lock lol. I take the key works in the ignition?Vagcom is software that allows you to run diagnostics on a car (to find/clear fault codes). It can do a bunch of other stuff including relearning keys. I had the same problem you had (the remote locking not working not the manual lock thing) and it turned out the keys just had to be relearned. It doesn't take lobg but you need the software. If you don't know anyone VW can do it for you. Quote Link to comment Share on other sites More sharing options...
Liamch Posted November 18, 2017 Report Share Posted November 18, 2017 I've just had to change the battery in my key and since then I can't lock or unlock my car with the key, not sure if it's just the key as my unlock button doesn't click down as the lock button does? But if anyone could help on how to reprogrammed the key? I only have the one key but I do have access to a diagnostic kit at my college. Quote Link to comment Share on other sites More sharing options...
Skezza Posted November 19, 2017 Report Share Posted November 19, 2017 You can adapt it using VAGCOM. Quote Link to comment Share on other sites More sharing options...
