JensonLEi Posted July 14, 2012 Report Share Posted July 14, 2012 Not really familiar with spacers so needed some advice on what are the best and what size shall i go for, arches have been rolled, wanting them on the back, 1 Quote Link to comment Share on other sites More sharing options...
Lupo Lewis Posted July 14, 2012 Report Share Posted July 14, 2012 I just put a set of 5mm on the back just to try it out, it didnt make alot of difference but it filled up the arch gap nicely. I've got 15" ATS cups ET 28. I think im going to put them on the front and get 10mm for the back.You dont need longer bolts unless you're getting anything above 10mm aswell. Hope this helps.Sweet lupo by the way Quote Link to comment Share on other sites More sharing options...
scotty_82 Posted July 14, 2012 Report Share Posted July 14, 2012 Walk over to car, measure the gap from the tyre to the arch, that's the max size spacer you can get without more work. Pretty bloody simply really Quote Link to comment Share on other sites More sharing options...
JensonLEi Posted July 14, 2012 Author Report Share Posted July 14, 2012 I just put a set of 5mm on the back just to try it out, it didnt make alot of difference but it filled up the arch gap nicely. I've got 15" ATS cups ET 28. I think im going to put them on the front and get 10mm for the back.You dont need longer bolts unless you're getting anything above 10mm aswell. Hope this helps.Sweet lupo by the way cheers mate! Quote Link to comment Share on other sites More sharing options...
Silver! Posted July 14, 2012 Report Share Posted July 14, 2012 What Scotty says really, measure the gap between tyre edge and arch and get the spacers which will fill the difference. If need be you can get your arches rolled.Hubcentric are best as they sit, like a wheel, on the hub\drum lip, then have a similiar projeting lip for the wheel to mount on.Up to a certain thickness, either 10 or 15mm you wil require longer bolts as they are "bolt through. Over that thickness they are bolt on and then the wheels bolt on to the spacer.All this will depend on the the wheel offset to, so if you decide to change your wheels, be prepared to change your spacers. Quote Link to comment Share on other sites More sharing options...
Ashh Posted July 14, 2012 Report Share Posted July 14, 2012 You dont need longer bolts unless you're getting anything above 10mm aswell. Hope this helps.ALWAYS get longer bolts. The bolts are that length for a reason, taking any amount off them is obviously a stupid move. I know from EXPERIENCE Quote Link to comment Share on other sites More sharing options...
