How to: Replace your aerial
I've been asked to do a how to on this so here goes...this is with an aftermarket shark fin aerial but it's one with the proper connector for the Lupo so it will be exactly the same for an OEM replacement.
For this you will need:
- A 22mm spanner
- An aerial
- About half an hour
That's it, dead easy. Also recommended (though I managed without) is a friend to help keep the new aerial straight while you bolt it on.
So many of you will find with 10 years + on your motor that the rubber seal on the aerial base has become faded, rotting or, like mine, completely rotten away
:surprised: I know right? Never fear, Koop is here.
I've cheated a bit as my headliner's already out for retrim. You should be able to just peel the back of the headliner off to get at the bits you need for this. The headliner has 2 of these clips at the back:
which clip into these holes at the back of the car -
- O/S
- N/S
You'll need to push up & forward on the back of the headliner (from the back with the boot open so it doesn't fall on your head) to pop the clips out, then peel the headliner down. You might need to take the C pillar trims out, they're just on push clips so a careful yanking will have them off. When you're done you should be able to see this lot:
First job here is unclipping the connector, first pop this little black clip open
Then pull back the bit of foam around the connector
To unclip it pull back on the little foreskin (hur hur) with one hand
and pull on the other connector with the other.
Now you can undo this nut with your 22mm spanner:
The nut & the other bit which clamps onto the inside of the roof should come away together
Then pull the aerial out from the top
You'll probably find it's a bit minging under there
so give it a good clean & polish
That'll do pig :thumbup:
Now take your new aerial - here's mine cunningly disguised as an iron
and remove the nut & clampy bit
Now feed the cable & thread through the roof
and get the aerial lined up nice & straight
Stick your bits back on the thread from the inside (loosely)
Here's where a buddy may come in handy, though I managed to reach round the tailgate to hold the aerial steady with one hand while tightening the nut by hand with the other. Then it was a case of tightening it up properly with the spanner - continually checking it hadn't become misaligned which if you have someone to hold it still you shouldn't have to do. I tightened it until I judged there to be a nice tight seal on the bottom of the aerial - I didn't want to do it too tight as I didn't want those teeth in the little clamp bit to dig into the roof too much.
Now the aerial's attached to the roof you can join up the connectors, just push til it clicks
roll back the foam cover...
...and clip it back in
Then refit your headliner (mine's staying out for now)
...and finally step back & admire your snazzy new aerial
  • Like 3
This topic is now closed to further replies.
