ToJo Posted April 6, 2012 Report Share Posted April 6, 2012 Hi, Recently bought a basic diagnostics tool.When scanning my 1.4 16v Sport it keeps giving me the fault code'00282 Throttle position actuator'I clear it and it comes back within a week or so.The idle is a bit inconsistent which I guess has something to do with it.Been reading around and do i need to re-allign the body?ThanksTom Quote Link to comment Share on other sites More sharing options...
electricracer Posted April 6, 2012 Report Share Posted April 6, 2012 you need to do a throttle adaptation, this runs the throttle body through a test and allows it to reset itself. as far as im aware the only way to do this is with vag com (think you will need full version) its dead easy to do but there must be no other faults before you do it Quote Link to comment Share on other sites More sharing options...
ToJo Posted April 24, 2012 Author Report Share Posted April 24, 2012 Ok thank you very much, I have a friend who has the full version of VagCom so will ask nicely! Quote Link to comment Share on other sites More sharing options...
Wee Sprocket Posted April 24, 2012 Report Share Posted April 24, 2012 (edited) Evening, according to my Autodata book, The fault is ' idle speed control (ISC) actuator/throttle motor'. The probable cause is:throttle valve tight/sticking,wiring,multi-plug incorrectly wired,ISC actuator/throttle motorI'd probably start with a good clean with a spray cleaner.Wee Sprocket Edited April 24, 2012 by Wee Sprocket Quote Link to comment Share on other sites More sharing options...
ToJo Posted April 26, 2012 Author Report Share Posted April 26, 2012 (edited) Right had the throttle body reset using VagCom.the 00282 Fault code came back within a day which is frustrating,at the weekend i'll give the throttle body and actuator a good clean to see if this helps.The person who reset the throttle body said they've seen this before but on a polo6n2 and they had to put in a new pedal box, could this be the same on the Lupo? Edited April 26, 2012 by ToJo Quote Link to comment Share on other sites More sharing options...
sharpelupo Posted August 23, 2012 Report Share Posted August 23, 2012 i no this is an old post but does any one know if you would have to replace the pedal box to solve this problem? got the same problem any one else got any ideas? would it be a major issue if i left it as it is? Quote Link to comment Share on other sites More sharing options...
