g60steve Posted March 21, 2012 Report Share Posted March 21, 2012 (edited) Hi,I've a slight problem with finding 1st gear on a MK1 Arosa 1.0S(1999) and wondered if anyone could point me in the right direction of how to adjust the gear linkage please?All gears work fine and I can find 2nd,3rd,4th,5th & reverse with no problem... it's just 1st gear that you have to go across the gate slighly towards reverse in order to select it.I've had a look in the "How to" section but I couldn't find anything on the linkage adjustment....apologies if I've missed it.Any help much appreciated. Edited March 23, 2012 by g60steve Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted March 22, 2012 Report Share Posted March 22, 2012 I think there is a guide on youtube, for VWs but will be the same Quote Link to comment Share on other sites More sharing options...
g60steve Posted March 23, 2012 Author Report Share Posted March 23, 2012 I think there is a guide on youtube, for VWs but will be the sameIf you mean the one by Dieselgeek then that's for 2000-2010 VW's so not the same as a 1999 Arosa/Lupo. Quote Link to comment Share on other sites More sharing options...
TArosa Posted March 27, 2012 Report Share Posted March 27, 2012 having the same problem with my arosa too mate (same year) but can be difficult to get 3rd some times too... let me know if you get it sorted Quote Link to comment Share on other sites More sharing options...
g60steve Posted March 28, 2012 Author Report Share Posted March 28, 2012 I've been told there's a 13mm bolt underneath the gearstick that requires slackening off,then adjust the lever to suit and then re-tighten the bolt.Not got round to having a go yet but I'll update if it cures the fault. Quote Link to comment Share on other sites More sharing options...
jonisonvespa Posted March 29, 2012 Report Share Posted March 29, 2012 you have to lock off the gear knob, then there is another lock off point at the box you could try to ease up the linkage at the box with silicon sealant first Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted May 4, 2012 Report Share Posted May 4, 2012 Did you get anywhere with this Steve? Quote Link to comment Share on other sites More sharing options...
jonisonvespa Posted May 4, 2012 Report Share Posted May 4, 2012 ok ive mastered this now if steve needs help Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted May 4, 2012 Report Share Posted May 4, 2012 I do - been wanting to do this on my Sport for a while Quote Link to comment Share on other sites More sharing options...
jonisonvespa Posted May 4, 2012 Report Share Posted May 4, 2012 (edited) right, its quite simplecar on jackstandsfirst check the two 13mm bolts that hold the linkage mechnisum to the box are nice and tight.then loosen the two nuts and bolts on the gear linkages.position the gear knob inbetween 1st and 2ndthen go and tighten up the two nuts and bolts so they are in the middle position of their slotscheck gears, they should be neary there,the afjuster that goes up/down vertically the one you can only see from the underneath adjust that one if your reverse is way outjust a case of tweeking itat least check the gear oil level, or at best change it. Edited May 4, 2012 by jonisonvespa Quote Link to comment Share on other sites More sharing options...
