si_leeds Posted October 1, 2011 Report Share Posted October 1, 2011 Our lasses polo has been sat since April with a ****ed gearbox, we've just had it replaced and obviously the battery was depleted so jumped it off and dis 40 miles, battery still flat.... Is this likley to be the alternator or just a goosed battery? have replaced battery and it seems okay but I don't want he breaking down if its the alternator lol Quote Link to comment Share on other sites More sharing options...
madmanncfc Posted October 1, 2011 Report Share Posted October 1, 2011 Have you got a multimeter?If you have check the battery voltage with the engine running it should be around 14 volts.Then turn on everything in the car and see if the voltage is the same. If it is then the alternator is fine.Hope that helps Quote Link to comment Share on other sites More sharing options...
si_leeds Posted October 1, 2011 Author Report Share Posted October 1, 2011 Cheers pal, got a mate who's got one so will give it a try Quote Link to comment Share on other sites More sharing options...
madmanncfc Posted October 1, 2011 Report Share Posted October 1, 2011 Little video to show what i mean Quote Link to comment Share on other sites More sharing options...
si_leeds Posted October 2, 2011 Author Report Share Posted October 2, 2011 You said if it stays the same its fine but the video says if it stays the same the alternaters goosed? Quote Link to comment Share on other sites More sharing options...
craigg!! Posted October 2, 2011 Report Share Posted October 2, 2011 the voltage will jump around, if its charging properly it should be around 14.5v if its just sat around 12v then your alternator aint charging Quote Link to comment Share on other sites More sharing options...
madmanncfc Posted October 2, 2011 Report Share Posted October 2, 2011 YeahWhen you start the car the voltage will jump to around 14v then you turn stuff on and if the voltage stays the same all is good.If you turn the car on and the voltage stays at 12 its goosed Quote Link to comment Share on other sites More sharing options...
si_leeds Posted October 2, 2011 Author Report Share Posted October 2, 2011 Sound cheers lads Quote Link to comment Share on other sites More sharing options...
