Ashh Posted August 4, 2011 Report Share Posted August 4, 2011 Fitted my coilovers last night (JOM bluelines, on a budget), and my standard GTI wheels rubbed on the springs and shocks themselves, on the front, so i've had to revert back to my steels !Is this to be expected with the ET and width of the wheels, or is there an issue with the coilovers?Also, what are the general rules with spacers, when will i require longer bolts/ Hubcentric B spacers?Cheers, Ash! Quote Link to comment Share on other sites More sharing options...
Kez1990 Posted August 4, 2011 Report Share Posted August 4, 2011 what tyre size is on the bathurst's? still i dont see why it should be rubbing :/ unless the tyres are balloons Quote Link to comment Share on other sites More sharing options...
Adam R4 Posted August 4, 2011 Report Share Posted August 4, 2011 Yeah, seems strange for them to be rubbing.Try some thin spacers, my baby G60's with their balloon tyres are about 5mm away from my spring. Quote Link to comment Share on other sites More sharing options...
Ashh Posted August 4, 2011 Author Report Share Posted August 4, 2011 Think i was running 205/50/15 on them... they came with the wheelsWhat Width are the G60's? Quote Link to comment Share on other sites More sharing options...
Cooper_GTI Posted August 4, 2011 Report Share Posted August 4, 2011 (edited) Longer bolts are generally required when you go above 5-8mm.This sounds strange though, considering that, at the end of the day, bathursts are standard Lupo wheels.The only difference on the gti is the ball joint, which is about 10mm longer to give a wider track, which works by pulling the hub further away from the shocks/wishbones.Have you tried adjusting the camber? If you're running loads of negative it could catch... Edited August 4, 2011 by Cooper_GTI Quote Link to comment Share on other sites More sharing options...
Ashh Posted August 4, 2011 Author Report Share Posted August 4, 2011 (edited) We've set it up to have as much positive camber as possible, still rubs on the suspension! I guess the longer ball joint could be an issue/fix, as to why they touch... I'll have to invest in some 8mm spacers and hope for the best! Edited August 4, 2011 by Ashh Quote Link to comment Share on other sites More sharing options...
ministig Posted August 4, 2011 Report Share Posted August 4, 2011 (edited) Tyres are too big if they are 205/50's, people have issues running 195/50 on a lowered lupo! 195/45 would give a relatively straight side wall on bathursts Edited August 4, 2011 by ministig Quote Link to comment Share on other sites More sharing options...
