chrisluke99 Posted June 21, 2011 Report Share Posted June 21, 2011 hi there! , so how do you remove the pin that holds the driver and passenger seats in? as i have some mk3 gti seats coming at some point!cheers! Quote Link to comment Share on other sites More sharing options...
Bickerton Posted June 21, 2011 Report Share Posted June 21, 2011 (edited) You undo the 2 nuts at the front and slide the seat back having removed the plastic trim off the runners Edited June 21, 2011 by Bickerton Quote Link to comment Share on other sites More sharing options...
chrisluke99 Posted June 21, 2011 Author Report Share Posted June 21, 2011 You undo the 2 nuts at the front and slide the seat back having removed the plastic trim off the runnerson mine there arent nuts?? one end is like a flat head rivet and the other has a cap on it :S Quote Link to comment Share on other sites More sharing options...
Bickerton Posted June 21, 2011 Report Share Posted June 21, 2011 So if you Stick your head in the footwell and look at your seat there aren't two nuts staring you straight in the face? Quote Link to comment Share on other sites More sharing options...
chrisluke99 Posted June 21, 2011 Author Report Share Posted June 21, 2011 So if you Stick your head in the footwell and look at your seat there aren't two nuts staring you straight in the face?i looked earlier and thats all i could see? ill probably see what your on about when it comes to taking them out Quote Link to comment Share on other sites More sharing options...
