Lupo gti
Missfires the whole way!
Just changed plugs again... No difference?
Just sounds boged down?
Fuel filter / bad fuel?
Going to borrow a few bits and bobs off the mother in laws 1.4 16v 100 bhp ibiza tomorrow!
Hope i get to the bottom of it asap as cars going sunday
That would throw up a warning light wouldnt it?
Yeah it would, I assume with this fault the eml must be on!
Engine check light is on
Getting it scanned tomorrow :)
Good, keep us posted!
Running better today the other half put somerfield 95ron in it
Heh, ditto. Works a lot better with decent fuel in it...
Saturday,04,June,2011,11:54:26:38917
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 6X - VW Lupo
Scan: 01 02 03 08 15 17 19 25 35 37 44 45 55 56
VIN: Edited!!!   Mileage: 160480km/99717miles
Address 01: Engine        Labels: None
  Part No: 036 997 033 E
  Component: 1,6l/4V SIMOS3  00HS7000
  Coding: 00031
  Shop #: WSC 00032
  VCID: 1D3A0813BD21
  WVWZZZ6EZ2W007817     VWZ1Z0B2014418
8 Faults Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
           P1503 - 35-10 -  -  - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
           P1602 - 35-10 -  -  - Intermittent
17751 - Ignition Coil Power Output Stage 2: Shorted to Ground
           P1343 - 35-10 -  -  - Intermittent
16687 - Cylinder 3: Misfire Detected
           P0303 - 35-10 -  -  - Intermittent
16686 - Cylinder 2: Misfire Detected
           P0302 - 35-10 -  -  - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
           P0300 - 35-10 -  -  - Intermittent
17953 - Throttle Valve Controller: Malfunction
           P1545 - 35-10 -  -  - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 6X0-907-379.lbl
  Part No: 6X0 907 379 C
  Component: ABS/EDS 30 IE CAN  V004
  Coding: 15603
  Shop #: WSC 01233
  VCID: 448C9D777E0B
No fault code found.
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
  Part No: 1C0 909 605 A
  Component: 2T AIRBAG VW51        02
  Coding: 12884
  Shop #: WSC 01233
  VCID: 22403BEF845F
1 Fault Found:
00532 - Supply Voltage B+
           07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 6X0-920-xxx-17.lbl
  Part No: 6E0 920 900
  Component: KOMBIINSTRUMENT BOO V10
  Coding: 00440
  Shop #: WSC 00032
  VCID: DFC6F21B77AD
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
  Part No: 6N0 909 901
  Component: Gateway K<->CAN
  Coding: 00022
  Shop #: WSC 01233
  VCID: F0E481A79A33
Address 25: Immobilizer        Labels: 6X0-953-257.lbl
  Part No: 6X0 953 257
  Component: IMMO                0008
  Coding: 00001
  Shop #: WSC 00000
  VCID: FDFAA893DD61
Address 35: Centr. Locks        Labels: 1C0-962-258-III.lbl
  Part No: 1C0 962 258 AB
  Component: 16 Zentr.Verriegel. 0003
  Coding: 00017
  Shop #: WSC 01233
  VCID: 67D66AFB2FFD
Address 45: Inter. Monitor        Labels: Redir Fail!
  Part No: 6N0 951 171 D
  Component: Innenraumueberw.    0003
  VCID: 3064C1A7DAB3
Address 55: Xenon Range        Labels: None
  Part No: 6N0 907 503
  Component: Leuchtweiteregelung 0003
  Coding: 00001
  Shop #: WSC 00000
  VCID: ECDC95D7B61B
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
  Part No: 6N0 035 186 B
  Component:  Radio BNO         0006
  Coding: 00403
  Shop #: WSC 01233
  VCID: 2D5AD8D3CD81
1 Fault Found:
00856 - Radio Antenna
           36-00 - Open Circuit
End   ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 15: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 25: DTCs cleared
Address 35: DTCs cleared
Address 45: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
VIN: WVWZZZ6EZ2W007817   Mileage: 160480km/99717miles
  Coding: 00031
  Shop #: WSC 00032
  VCID: 1D3A0813BD21
Readiness: 1110 0101
  Coding: 15603
  Shop #: WSC 01233
  VCID: 448C9D777E0B
  Coding: 12884
  Shop #: WSC 01233
  VCID: 22403BEF845F
  Coding: 00440
  Shop #: WSC 00032
  VCID: DFC6F21B77AD
  Coding: 00022
  Shop #: WSC 01233
  VCID: F0E481A79A33
  Coding: 00001
  Shop #: WSC 00000
  VCID: FDFAA893DD61
  Coding: 00017
  Shop #: WSC 01233
  VCID: 67D66AFB2FFD
  VCID: 3064C1A7DAB3
  Coding: 00001
  Shop #: WSC 00000
  VCID: ECDC95D7B61B
  Coding: 00403
  Shop #: WSC 01233
  VCID: 2D5AD8D3CD81
Edited by Big Jase
So basically
Low batt (probs from me disconnecting it last night)
Load sensor wire (common fault and hasnt caused any issues since last scan)
Radio antenna (has sharkfin fitted)
And all the rest are due to poor fuel, car is fine after 200 miles ov vpower, no eml's any more
It's wierd how a few people seem to swear by vpower, I've never used it, usually tesco's own and I've never had any running issues! Glad you got it sorted though matey.
Yes but try running your car 100% on high octane over thousands of miles, then dropping 3 octane the cars almost had a heart attack
Gtis are supposed to run on high octane, running lower octane can severly reduce the engine lifetime, yours will be 'knocking' quite a bit id say
