BEBBSTER Posted January 10, 2011 Report Share Posted January 10, 2011 Hey I fault found a few codes on my 1.4 Lupo Sport, wondering if anyone could tell more about them.4 Faults Found:17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction P1196 - 35-10 - - - Intermittent17598 - Linear O2 Sensor; Reference Voltage: Implausible P1190 - 35-10 - - - Intermittent16502 - Engine Coolant Temp. Sensor (G62): Signal too High P0118 - 35-10 - - - Intermittent16705 - Engine Speed Sensor (G28): Implausible Signal P0321 - 35-10 - - - Intermittent Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 10, 2011 Report Share Posted January 10, 2011 (edited) I would delete the codes see what comes back.Looks like you have a lambda sensor issue. Edited January 10, 2011 by 99hjhm Quote Link to comment Share on other sites More sharing options...
BEBBSTER Posted January 10, 2011 Author Report Share Posted January 10, 2011 Ive cleared the codes il try them again friday, ive been reading up and the engine speed sensor is the crankshaft sensor which could cause engine cut out! which is whats happening with mine, they are only £20 so im gona give it a go Quote Link to comment Share on other sites More sharing options...
99hjhm Posted January 10, 2011 Report Share Posted January 10, 2011 Ive cleared the codes il try them again friday, ive been reading up and the engine speed sensor is the crankshaft sensor which could cause engine cut out! which is whats happening with mine, they are only £20 so im gona give it a goSorry I misread that code, DOH! Yes, good chance it is the engine speed sensor, probably located on the cam cover. Quote Link to comment Share on other sites More sharing options...
