[help] removing the light switch
Hugopq
Damn Philly's living up to his name.
As above, with the switch in the off position, push in and twist to the right, it'll come free of it's mounts and slide forward, then remove the cables from the back.
Does this work the same with the fan control switch? Mine appears to be nothing on speed 2... any ideas on that welcome, alternatively I'll need to order a new switch.
I think the fan ones just pull off - there's a how to on replacing the light behind it so that should say how to remove the dial. I think if it stops working, it just needs a new resister pack, or something ;)
