gti conversions for dummies
loopmuscle
decided to make this thread so everyone can stop asking how to do the conversions.
also find out why everyone says polo gti looms are easier.
done this conversion three times now so iv got the idea how you do it
you will need
polo gti engine
polo gti looms inside and out
polo gti or lupo gti ecu
and if you have cable throttle get the gti, sport, pedal box
electrical
CENTRAL LOCKING
easiest way to do central locking is to use your old loom( if it has central locking)
strip the loom down starting from the drivers side door connecters seperator the central locking wires from the other wires.
do the left side door connector firstly to the fusebox and also to the drivers side wires where they attach. secondly down to the boot of the car where they lead to the boot lock and interior lighting.
do the same to the polo gti looms while also taking out the air pump pipes.
the boot wires need to be chopped or either the pins need taking out the connector blocks
once done put the old looms to the gti ( best to go fusebox first)
the polo gti looms may have extra peices going off near to the rear speakers these where the interior light sensor connects and are no longer needed
once all fitted, soldered,crimped etc
test the central locking using your original central locking control unit.
if remote test your fob should still work without reproggramming
wrap up the loom securly as you wont need to take that bit apart again.
this loom also does your electric windows if you have them.
LIGHTING
front light pins will need swopping and so do the rears
the 3rd brake light pin needs to be swapped over else you will find the 3rd brake light will not work ( obvs) but also the fuse will keep popping
the reverse light pin will need to be chopped and made into a double wire to use for both lights as the polo only uses one reverse light.
EARTHING/REAR RE-WIRING
the looms shape is diffrent to the lupo so your will need to unwrapp the whole of the rear loom to relocate the earths for the rear lighting ,fuel pump etc
the roof lining needs to be removed to swop the aerial cable to the other side or can be extended with more aerial cable.
ENGINE/GEARBOX
extra pieces will be need to do small but important bits of the conversion
the speedo sensor will need changing or chopping.
fitting the engine is just the same as putting the normal one in unless it is a 1.0 ltr then you need new engine mounts and a 1.4s,sport,gti gearbox
the gearbox bolts will need to be change for either gti bolts or you can chopp them to fitt
advice you to do the conversion on a abs type lupo as the abs one is more just plugg in and off you go.
the non abs will need you to rip the bulb out of the clocks and hide the wiring your chopp it.
throttle bodie has more air pipe hole in that will need either unscrewing and blocking or tubed to one another.
if you do not have air con take the pump off and the gti steering pump with it and replace with the 1.4 pump the belt you need is 11.4 s belt.
as for the cooling fan your need the relay off the gti that goes in the engine bay they are also on lupo gti's
connect this all up and get a garage to test it with daignostic tool
everything else is the same as the 1.4 so if you know how to take it now you know how to put it back in!
HEATING
the gti heaters use electric motors and a electronic computer to adjust the heating and location of the blowing air
you can fit these in or you can simple chop the live which is the black and red large wire and solder it, female connect it to the orginal heater connector with the earth done the same aswell.
everything else is a plug and play game
done this so people that want to do the conversion have an idea what there getting into!
Are you a mechanic? Do you fancy doing another? Iv had one done my monkeys and its all gone wrong...
hi mate
were are you based ?
if your local i can come have a noisy and see what damage they have done.
what is it car exactly not doing? does it turn over? fire up and die? nothing works at all?
what looms are you using?
okay mate
well if he can tell me whats up with it?
i can help out :)
As far as I can remember from looking at it and speaking to Rich...
The garage have botched in a Polo GTI engine with the cylinder head from his Lupo sport engine and the cams from the Polo GTI engine.
It's still running the original Lupo sport ECU.
Basically it's Frankenstein's monsters GTI engine conversion!!
okay the problem is with that is the crank flow is different from the 1.4 to the 1.6 someone has done this before and what they had to do is take out the crank sensor timing gear and swop them over so the ecu new when to fire correctly.
but to be honest i couldnt see that working amazing and you might as well block the egr valve and skim the head to the same compression of the gti or do the gti conversion properly
hi mate did they start mixing the engine together?
if i was you id do it yourself or get someone who knows these engines to re build it then do your looms and ecu for you.
Indeed, propper mechanics with 2 proppper units, but they are terrible,
Yea, i may PM you if i decide to re do the gti conversion,
Thanks.
So what is the advantage of using a Polo GTI engine instead of a Lupo GTI one?
Sorry if i'm missing something obvious!
I Think with the right tools and all the bits you need there and then you could probably do this conversion over a weekend with two people. Hope you get yours sorted Rich nothing worse than a pikey job. :)
  • 6 months later...
yes you can use your exhaust manifold. gearbox. driveshafts. radiator. most of your coolant piping but you need to get oil cooler linked up.
you can use all the engine mounts as long as its 16v engine.
you can use the flywheel clutch etc.
the main things you need is complete whole car wiring loom. engine. ecu transponder box and chip. decent tools to get interior and dash out.
you will need the gti intake manifold and gti airbox.
there could be a few more bits.
if you pm me with any questions or problems its fine, me and loopmuscle are currently in a 1.4s to gti conversion with front hubs rear beam, abs system so we will be doing everything needed with new looms the lot so just drop a pm
