Richud Posted September 19, 2010 Report Share Posted September 19, 2010 got corrado 280 discs on the way just wanna know what pads i need, i think you can use either standard gti pads or g60 pads...... whats best to go for? im thinking ferodo Quote Link to comment Share on other sites More sharing options...
99hjhm Posted September 19, 2010 Report Share Posted September 19, 2010 got corrado 280 discs on the way just wanna know what pads i need, i think you can use either standard gti pads or g60 pads...... whats best to go for? im thinking ferodoThey are the same. But because the discs are 3mm thinner on the 280mm setup you can get away with thicker (19mm) pads. I think these are fitted to unvented Mk2 GTI discs? But also the Ibiza Cupra. Std G60 and Lupo GTI pads are 15.6mm. This gives better pedal feel as there is less flex in the calipers(Look for yourself, the calipers flex alot!), longer life and more resistant to brake fade as there is more pad to heat up. If you have the money, I would consider pagid pads if you have the money.. RS4-2-1(Black's) should be best, never tried them though.http://www.pagid-brake-pads.co.uk/products/ Quote Link to comment Share on other sites More sharing options...
Richud Posted September 19, 2010 Report Share Posted September 19, 2010 bit more than im willing to spend those pagid pads, will go up to 100 bucks i think. so go for the thicker 19 pads yer? am i looking for the earlier model ibiza cupra items? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted September 19, 2010 Report Share Posted September 19, 2010 bit more than im willing to spend those pagid pads, will go up to 100 bucks i think. so go for the thicker 19 pads yer? am i looking for the earlier model ibiza cupra items?Yes, with the 1.8 20vT engine 1999-2002. Quote Link to comment Share on other sites More sharing options...
Richud Posted September 19, 2010 Report Share Posted September 19, 2010 thanks squire! Quote Link to comment Share on other sites More sharing options...
99hjhm Posted September 19, 2010 Report Share Posted September 19, 2010 thanks squire!Also, it's the Lucas calipers not the Brembo ones on the Ibiza. Quote Link to comment Share on other sites More sharing options...
Richud Posted September 19, 2010 Report Share Posted September 19, 2010 i think ferodo only made pads for the rear of said model lol.......nothings easy isit Quote Link to comment Share on other sites More sharing options...
Richud Posted September 22, 2010 Report Share Posted September 22, 2010 the brembo max discs have arrived but there thickness is 20mm, i have bought standard thinkness lupo pads. is the brake bite point gonna be through the floor? Quote Link to comment Share on other sites More sharing options...
99hjhm Posted September 22, 2010 Report Share Posted September 22, 2010 the brembo max discs have arrived but there thickness is 20mm, i have bought standard thinkness lupo pads. is the brake bite point gonna be through the floor?20mm? Whats the part number? No the pedal wont be that much different as your not pushing any more fluid. Quote Link to comment Share on other sites More sharing options...
Richud Posted September 22, 2010 Report Share Posted September 22, 2010 iv just loooked again and it says minimum thickness 20mm. part number: 09.6728.75 Quote Link to comment Share on other sites More sharing options...
99hjhm Posted September 22, 2010 Report Share Posted September 22, 2010 iv just loooked again and it says minimum thickness 20mm. part number: 09.6728.75Thats right, same as I fitted to mine, the grooves are machined 1mm deep so you know when they are worn out. Quote Link to comment Share on other sites More sharing options...
Richud Posted September 22, 2010 Report Share Posted September 22, 2010 rite ok i got you iv got tarox pads on the way for these discs. Quote Link to comment Share on other sites More sharing options...
WRC Posted April 14, 2016 Report Share Posted April 14, 2016 lets talks race brake pads for front 280 discs. except for some Ferodo DS300 applications, which one do you recommend? stock discs or..? i saw same Cl on kamracing.. http://www.kamracing.co.uk/car-tuning/volkswagen/vw-lupo/brakes/vw-lupo-cl-brakes-race-brake-pads-1-6-16v.html how are these? Quote Link to comment Share on other sites More sharing options...
Särås Posted April 15, 2016 Report Share Posted April 15, 2016 Will run my G60 upgraded brakes on my Lupo GTi with Carbotech XP20 in the front and XP8 in the rear. Had been running OEM brakes with Carbotech XP8 in the front and they where very good! Quote Link to comment Share on other sites More sharing options...
WRC Posted April 25, 2016 Report Share Posted April 25, 2016 carbotech does pads for front Lupo GTI? can you provide me with some links..or codes? thank you! Quote Link to comment Share on other sites More sharing options...
Silver! Posted April 25, 2016 Report Share Posted April 25, 2016 I run Brembo 280mm discs with Tarox Strada pads, 5.1 fluid and braided hoses. Good breaking from cold. Quote Link to comment Share on other sites More sharing options...
Silver! Posted April 25, 2016 Report Share Posted April 25, 2016 1 hour ago, WRC said: carbotech does pads for front Lupo GTI? can you provide me with some links..or codes? thank you! Not sure if this is the best pricing and there's no rears listed, but... http://www.cambridgemotorsport.com/multiterm/74890,83662 Quote Link to comment Share on other sites More sharing options...
WRC Posted April 25, 2016 Report Share Posted April 25, 2016 thank you, that will do Quote Link to comment Share on other sites More sharing options...
