loopzmatt Posted June 5, 2010 Report Share Posted June 5, 2010 so a bracket on my back box has snappedso took it to my local ats and theyve quoted me just over £170as everything cat back is one piece?is this true? Quote Link to comment Share on other sites More sharing options...
northwick Posted June 5, 2010 Report Share Posted June 5, 2010 Difficult to say without looking but I'd certainly run it down to a local welding place and see if they can weld the bracket back on (or weld a new piece onto it) if the actual exhaust is still sound. Quote Link to comment Share on other sites More sharing options...
loopzmatt Posted June 6, 2010 Author Report Share Posted June 6, 2010 tbf the back box isnt in great conditionjust was unsure about it all being one piece from the cat back? Quote Link to comment Share on other sites More sharing options...
jasper Posted June 6, 2010 Report Share Posted June 6, 2010 i got told this too. they wanted 200+ so i took it to a local garage who could weld and got just a new back box fitted for around 60 quid. Quote Link to comment Share on other sites More sharing options...
Picola Posted June 6, 2010 Report Share Posted June 6, 2010 thats bollox, 2 piece im sure Quote Link to comment Share on other sites More sharing options...
loopzmatt Posted June 6, 2010 Author Report Share Posted June 6, 2010 well ill just habve to try a few places see what they sayunless someone can confirm 100% Quote Link to comment Share on other sites More sharing options...
Mitchell Posted June 6, 2010 Report Share Posted June 6, 2010 sure they join over rear axle why not get under your car and look. Quote Link to comment Share on other sites More sharing options...
LupoEnvy Posted June 14, 2010 Report Share Posted June 14, 2010 If its a 1.4 s (not sport) there are three parts to the exhaust - all possible to separate - (1) The cat (around £150), the middle part (about £50 or so), and the back box (about £50 or so). In which case they're charging you £120 for welding etc. Try somewhere else!!! I got mine done at a 'Mr Tyre' (West Midlands). Quote Link to comment Share on other sites More sharing options...
jon_273 Posted June 15, 2010 Report Share Posted June 15, 2010 You're both right. Let me explain.If your car has the original factory exhaust then it will be in one piece from the cat back. Presumably because when they build the car they fit the exhaust before they fit the rear beam.When you buy a replacement exhaust the backbox and centre boxes come as separate sections. You buy the bit you need along with a sleeve, then you cut the exhaust in half underneath the car and fit the new bit using the sleeve. Job done Quote Link to comment Share on other sites More sharing options...
waffenman67 Posted June 21, 2010 Report Share Posted June 21, 2010 Just had the new back box fitted to my wife's 1.4s at my local VW friendly,they charged me £80(£50 for the box,rest for fitting). Quote Link to comment Share on other sites More sharing options...
