Silver!
How To Add Photos to Forums
HOW TO ADD PHOTOS TO FORUMS
1. Join a picture sharing site such as photobucket. Il use photobucket in this guide as Im already a member.
2.Once you have logged in, click on Upload Images and Videos. Make sure you have "from computer" checked on the right hand side.
3.A File selection window will open and from here you can select as many photos you like to upload. Select the photos you want and click"Open"
4.Photobcuket will now begin to upload the photos showing a progress bar with a percentage
5.When the photos have finished being uploaded the window will change to show only the photos that have just been uploaded. Once you have looked over your uploads click on "Save and Share now"
6.You will then end up at another view of the photos you have uploaded. From here click on "Return to album"
7.You will now be back at the main album view window where you can select the IMG Code to copy in to your text on the forum you have chosen to post your images on. Hover over the image you want to post with you mouse and right click in the "IMG Code" Window and select copy.
8.Now back in your Forum text view, Copy the IMG Code in to the text area.
9.Now your image will appear in the forum when you post your text.
Hope this all helps
Cheers
Tom
This topic is now closed to further replies.
