si_leeds Posted March 15, 2010 Report Share Posted March 15, 2010 Over the last few days when I come to a stop my idle has dropped and then it reva its self a bit and sorts it out, but sometimes it cuts out altogether, but when I turn the key it starts again first time, any ideas please anyone? Quote Link to comment Share on other sites More sharing options...
si_leeds Posted March 18, 2010 Author Report Share Posted March 18, 2010 Anybody? Quote Link to comment Share on other sites More sharing options...
cjr1990 Posted March 26, 2010 Report Share Posted March 26, 2010 i have a similar problem with my 1.0 seat when idle revs are below 1000 and it keeps trying not too stall Quote Link to comment Share on other sites More sharing options...
The Dj Posted April 20, 2010 Report Share Posted April 20, 2010 alrighthad this problem with my mk1. me and me mechanic changed between us ht leads, plugs, throttle body air filter and checked fuel filters n everything to no real joy!!was at scrap yard one day and came across near new dizzy cap! now seams to be working a treat with that and a new rotor arm chris Quote Link to comment Share on other sites More sharing options...
si_leeds Posted April 21, 2010 Author Report Share Posted April 21, 2010 sweet cheers mate.it stopped doing it for a few weeks and then did it three times on the way home from work last night Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted April 21, 2010 Report Share Posted April 21, 2010 Give the throttle body the good news with a can of carb cleaner, see if it improves things. Quote Link to comment Share on other sites More sharing options...
chrisluke99 Posted April 23, 2010 Report Share Posted April 23, 2010 yes mate i have the same problem with my car... but i had a look in the air box and found a pipe that leads to the sump ...to be honest i dont know what it does but i cleaned it out because it was gunged right up and it seems to run fine now but check yours it could be the problem !cheers ck Quote Link to comment Share on other sites More sharing options...
Defcon5 Posted April 23, 2010 Report Share Posted April 23, 2010 yes mate i have the same problem with my car... but i had a look in the air box and found a pipe that leads to the sump ...to be honest i dont know what it does but i cleaned it out because it was gunged right up and it seems to run fine now but check yours it could be the problem !cheersckCrank case breather - gunk comes through this pipe and ends up gunking your throttle body. it contains a small heating element which can fail causing it to become blocked Quote Link to comment Share on other sites More sharing options...
jonnykell1980 Posted April 24, 2010 Report Share Posted April 24, 2010 blocked breathers (pcv) definately cause idle problems on some engines so would start there, ive experienced this fault on lots of different engines and tends to be an idle air control valve, would this engine have one of these? Quote Link to comment Share on other sites More sharing options...
si_leeds Posted April 27, 2010 Author Report Share Posted April 27, 2010 so just take the breathers off and look through them and try clean them out? and same with the throttle body?and i would of thought it would have an idle air controll valve, will check up on that though because im not 100% Quote Link to comment Share on other sites More sharing options...
Unheard Posted April 27, 2010 Report Share Posted April 27, 2010 First things first check for cracks in your brake servo vacume hose this is a known problem so from simply a safety point of view you want to check that out. If that is cracked then it is an easy fix. The other thing that will cause the same sort of problem is a screwed vapor canister solenoid. Its a little blue and black thing with a pipes coming out of each end. It can be found on the drivers side of the engine bay. To check if that is the problem you can pull the plug on it and clamp off one of the pipes. By pulling the plug you will get awarning light on the dash but its nothing to worry about you are 100% safe to drive the car. The worst that will happen is the engine will go into open loop and you may use a little extra fuel but you may get a little added power . Once you plug it in again the engine light will go off in a shot time when driving. IBoth issues cause the same problem. They allow too much air to enter into the engine without the ECU accounting for it. You may find when you slow down the engine dips then revive its self as the ECU has realised oh crap i need to chuck in a bit more fuel but if it dips too fast the engine will die. It may be totally unrelated to the above but its another few things to check. Quote Link to comment Share on other sites More sharing options...
DarkStryder360 Posted April 30, 2010 Report Share Posted April 30, 2010 This is a sexy thread. Mine cuts out about 2wice every journey! Cleaned the breather pipe mentioned and it some how made things worse? The throttle body though, I never touched it, mainly because I had nothibg to clean it.Carb cleaner was mentioned? Just poor it in or take the part off and clean? As much help would be t'riffic! Fed up of my car ruining my life! Lol =/ Quote Link to comment Share on other sites More sharing options...
NOCK Posted April 30, 2010 Report Share Posted April 30, 2010 This is a sexy thread. Mine cuts out about 2wice every journey! Cleaned the breather pipe mentioned and it some how made things worse? The throttle body though, I never touched it, mainly because I had nothibg to clean it.Carb cleaner was mentioned? Just poor it in or take the part off and clean? As much help would be t'riffic! Fed up of my car ruining my life! Lol =/I take mine off to clean from time-to-time and I'm no mechanic so it can't be that difficult. Problem with cleaning it on the car is that you can only clean one side as you can't get underneath the butterfly (I think that is what they call it) properly. Quote Link to comment Share on other sites More sharing options...
jonnykell1980 Posted May 2, 2010 Report Share Posted May 2, 2010 always take it off if you can, if you dont allow the cleaner a bit off time to evapourate off. only problem with leaving it on is any tar, dirt or grime you wash off has the chance of going into the engine. also brake cleaner is great for cleaning parts. Quote Link to comment Share on other sites More sharing options...
si_leeds Posted May 8, 2010 Author Report Share Posted May 8, 2010 First things first check for cracks in your brake servo vacume hose this is a known problem so from simply a safety point of view you want to check that out. If that is cracked then it is an easy fix. The other thing that will cause the same sort of problem is a screwed vapor canister solenoid. Its a little blue and black thing with a pipes coming out of each end. It can be found on the drivers side of the engine bay. To check if that is the problem you can pull the plug on it and clamp off one of the pipes. By pulling the plug you will get awarning light on the dash but its nothing to worry about you are 100% safe to drive the car. The worst that will happen is the engine will go into open loop and you may use a little extra fuel but you may get a little added power . Once you plug it in again the engine light will go off in a shot time when driving. IBoth issues cause the same problem. They allow too much air to enter into the engine without the ECU accounting for it. You may find when you slow down the engine dips then revive its self as the ECU has realised oh crap i need to chuck in a bit more fuel but if it dips too fast the engine will die. It may be totally unrelated to the above but its another few things to check.will try that mate, what should i clamp the pipe with? some molegrips or something? Quote Link to comment Share on other sites More sharing options...
