99hjhm Posted March 12, 2010 Report Share Posted March 12, 2010 (edited) Your car will need central locking for this mod to work, and all your door locks will need to be in fully working condition. I have tried the adaptions highlighted in red on my GTI, all others should work, but I can't gaurantee it.Auto locks are standard on many later VW's, but it is possible to enable this on Lupo's. Via channel 35 on VAG-COM. Selective Unlocking: [select] [35 - Cent. Locks] [Recode - 07] Write down the existing coding for future reference. Enter 5-digit code from below [Do It!] Look at the existing Soft. Coding. If you have selective unlocking (press the unlock button on the remote once to open the driver's door, twice to open all the doors) the last digit of your coding should be an even number. To make all doors unlock, add 1 to the coding. So, (xxxx4) add one to make it (xxxx5) so that all doors unlock with one press of the unlock button.Lock/Unlock Horn/Flash: [select] [35 - Cent. Locks] [Adaptation - 10] Channel (03..08) Adaptation Value (1 = on, 0 = off) [save] Channel 03 Auto Lock (This will automatically lock the vehicle when the vehicle speed reaches 15mph) Channel 04 Auto Unlock (This will automatically unlock the doors when the key is removed from the ignition barrel) Channel 05 Unlock, horn sounds Channel 06 Lock, horn sounds Channel 07 Unlock, turn signals flash Channel 08 Lock, turn signals flashJames. ** ALL USER GUIDES ARE INTELLECTUAL PROPERTY OF THE AUTHOR, NOT CLUB LUPO ** Edited October 10, 2010 by nfbr Link to comment Share on other sites More sharing options...
