dj-jay Posted February 27, 2010 Report Share Posted February 27, 2010 (edited) HI GUYS, FIRSTLY WITH THIS JOB U NEED A T15 SOCKET OR SCREWDRIVER, AND A 10MM SOCKET AND HALF INCH SOCKET,START WITH THE OUTSIDE PLASTIC CAP LIFTING IT UP TO REVEAL A HALF INCH BOLT, REMOVE THAT AND WAGGLE THE WINDOW WIPER OF,THEN USING YOUR T15 SCREWDRIVER ON THE INSIDE OF THE BOOT WHERE THE 2 GRAB HANDLES ARE,WITH YOUR BOOT UP FULL ONCE THE 2 SCREWS ARE REMOVED START AT THE TOP PULLING THE COVER TOWARDS YOU TO UNDO 4 WHITE PLASTIC CLIPS, THEN THE REST OF THE PANNEL SLIDES OF BOTTOM WAYS,THEN THERE IS 3 10MM BOLTS TO REMOVE, THEN ELECTIC PLUG AND WATER PIPE, I BENT MY PIPE OVER AND PUT A SCREW IN THE END,THEN CABLE TIED IT ALL UP FOR NEATNESS,ONCE 3 BOLTS ARE OUT MOTOR JUST POPS OUT,REFIT PANEL AND JOB DONETHE REPLACEMENT GROMIT U NEED IS AVAILABLE FROM HALFORDS AND ITS 25MM PART NUMBER HFX321 AND ITS 1.60P** ALL USER GUIDES ARE INTELLECTUAL PROPERTY OF THE AUTHOR, NOT CLUB LUPO ** Edited October 10, 2010 by nfbr 1 Link to comment Share on other sites More sharing options...
