"Lupolo" 1981 Polo with Hybrid Lupo GTI Lump
grungeisdead
Model:
X Reg 1981 Mk1 Polo LS
Engine:
90k 1398cc 1.4 16v Head
Schrick Fast Road Cams
42k 1598cc 1.6 16V Bottom End
Lupo GTI 5-Speed Box with Cable Clutch Conversion
Suspension:
Fully Adjustable Front Wishbones
Rose jointed Camber adjusting top mounts
Strengthened strut tops
Lupo Gti Front Shocks and Springs
Mk1 Polo Steering Arms
Lupo Stub Axles
Powdercoated Rear Axle
Mk1 Polo Rear Suspension - to be upgraded at some point
Shell Modifications:
Bulkhead removed
Seam welded
Modified Gearbox Mount for Lupo Gearbox & Retained Original Mount
Blanked Rear Wiper Hole
Spare holes welded up in firewall
Heater matrix welded up
Box Section Mounting Plates for Bucket Seats
Interior:
Koenig Fixed Back Reclining Bucket Seats
Schroth 3 Point Harnesses with Safety Devices Pre-Tensioners
Motorsport Fire Extinguisher
Exterior:
Pre 78 Spec Polo Flat Grille & Headlights
Brakes:
NOS Mk1 Master Cylinder
Lupo GTI 256mm Brakes
New Brake Lines
200mm VW Rear Shoes
Wheels and Tyres:
OZ Routes 14" x 7J
195/45/14 Hankook Ventus K102
Parts to get :-
Rear Axle Bushes
Larger Master Cylinder
200mm Rear Drums
Handbrake Cable
Braided Hoses
All my welding was carried out by Gray & Dave from Retro Rides 07815 750 531 Based in Leigh. (Full resto, custom welding and mot work, basically anything) Really good prices
Here's the car back in the day, 2 formor owners ago, and the man who comissioned the conversion into lupo gti spec by AWTracksport, they are based up in lincoln way, which is where the car was born, it still has the original dealer stickers, and keyfob in good condition, since then its been to preston and manchester
I spotted it up for sale at &1500 quid on ebay with no bidders, full on sleeper spec as pics above with a full sd cage, emerald ecu and other goodies, however i bought this instead
a year or two passed and i was finishing my last ever uni exams, and my side project (read: REAL disseratation =P ) was ready to go for its mot, maiden voyage was fine but the mot'rs were too busy to fit me in that day, so call back on monday.
unfortunatly this happened on the way there =[
devvoed at the loss of my baby, i was after another project and i saw the polo come up again for sale, this time as a rolling shell, most of the parts had been sold off.
at 400 quid i wasnt going to let the little car get away again, and popped up to see Trooper25 off Clubpolo in Preston who had bought it privately from ebay.
After chatting to him, he had wanted to use the car for rallycross, but the low lying sump meant the engine would need to be raised dramatically to be even viable, so he had stripped the motor completely and started seam welding the shell & removed the firewall as well as drilling out the spot welds on the seat runners and removing them but hadnt welded in seat rails with box section yet.
anyway he took a ride in a 205 gti mi16 and decided to sack off the poor little polo for something with real rallycross potential.
so i got the shell for 400 notes with the subframe and custom modifications
i then thought i should ask about the engine, is it still about, and his reply was you can have the engine and all the spares for 100 quid.
SCORE!
So I was a happy bunny, another project to sink my teeth into.
I've done various bits on the car, wirebrushed and por-15d the interior, front and rear panels and engine bay on the hunt for rust and por-15d all the good metal after a dousing with metal ready, started building it the new rear axle to find some small holes under cracked underseal in the rear arches so I put a wanted up on RetroRides for some local welders
these guys sorted me out a treat
http://retrorides.proboards.com/index.cgi?action=display&board=pfsw&thread=73142
anyway they carried out loads of bits for me
box section for bucket seats
rebuilding leading front edge of wing
couple of peppered small holes in inner rear aches - which was going to be the mot fail that set me off on wanting to get welding done on her
re-welding in of a mk1 gb mount as it was cut out when the lupo box was used
some various other holes around the body
blanking off heater matrix
welded up the exhaust on my mk2 afh conversion
made a few other custom bits for the engine conversions
, I would fully recommend the guys
so while the mk1 was away i was free to think about the powerplant, i always wanted the Polo GTI full lump and was going to wire it up oem but needed to many parts and i didnt want to overcomplicate things for a little lightweight blat about car. so then i got hold of some R1 ITBs with an inlet manifold for the engine, but that warranted for aftermarket management and mapping = mega money!
I have another car, a yellow mk2 and i converted that to a 1.4 16v AFH and was running it on bike carbs,
full thread here
Conversion FAQI wrote up to help collate all the knowledge i'd gained through reading on the net, friends and some experimentation
but i blew up the engine, bottom end was kaput, but the head and more importantly my shexy schrick cams were OK, so after reading about Jez's, Mitchells and others hybrid creations, i thought i want to retain the lupo block so i can call the car the lupolo, and by using an AFH head, i can use a set of bike carbs and a mk2 ignition setup which i have spare to get the engine up and running cheap and quickly in comparison to the steep start up costs of throttle bodies.
anyway details of the new engine
Mk4 1.4 16v AFH Head
Lupo 1.6 16v GTI Bottom End
CBR600 Carbs
It will be running the lupo 5 speed gearbox, running a cable clutch conversion with the cable operated 5 speed shifted in the car
I used an afh headgasket, polo aex headbolts, afh relay roller(modified)
Note, 6n 1.0 AER & Non AVY GTI lumps have the correct length headbolts
6n Polo 1 Litre
036103384B
bolt, with multi-spilne socket head
M9X1,25X138 / AER,ALL
Lupo GTI
036103384B
M9X1,25X138 / AHW,AKQ,APE, AUA,BBY,AFK, ANM,AQQ,AUB
Polo GTI
036103384E
M9X1,25X97 / AVY
The correct part from GSF is
01163
CYLINDER HEAD BOLT
PO 1.4 AFK/AHW/APE/AUA/AUB Engines 99> & PO 1.0 AER Engine 96>99
£2.00 each and you need 10.
the relay roller
part number 036109244
the guys made me a bar threaded to 10mm at one end to fit into the block and 8mm to fit through the sleeve of the roller, it was impossible to drill through for guys with thousands of pounds worth of machinery so don't bother trying it at home, I'm glad I didnt bother!
cambelt fitted and everything timed up, engine plate and alternator fitted
mated to the 5 speed lupo gearbox
disclaimer :- I've not ran the engine yet, so it may all end in disaster but no harm if it does, as if it doesnt, its going to be a little screamer
will add some pics in a bit of the current state after welding when ive got the bloody bluetooth working on my laptop
I've said it before about that Polo, but I'll say it again - it's nigh-on perfect!
:lol: cheers man, no where near perfect but i rag my cars haha :wub:
well some updates on the shell
i poked this bit of filler to reveal this
which when provoked more turned out to be a full rotton corner of the wing but all was done well by Gray.
this was welded up but i couldnt get decent pics of it after in the dark
Welded up heater matrix
seat rails
patched up some holes on the rear panel
mk3 gearbox mount back in
dewipered bootlid
mmm
so need to get the bare metal cleaned up, skim of filler on the external bits and por15 on the seat rails, and get a lick of primer and paint on the fresh welded bits, i can deal with mismatched paint at the moment
then i need to get some 200mm drums and finish rebuilding the rear axle, and rest of brake lines, get all those plumbed up and bled and the engine can go back in along with the bucket seats and harnesses.
inside in going to be bare as ****, just 2 buckets, harnesses and a fire extinguisher.
  • 3 months later...
well after another sabbatical, work continues on the mk1 this weekend,
some goodies to fit
200mm passat rear drums, back plates, stub axles and wheel cylinders, new vw shoes and bearings.
256mm ebc x-drilled grooved discs, lucas 54 calipers and ferrodo ds3000 pads
and the new lump is nearly done, just need to get a water pump, gearbox and clutch kit and woop.
its now an 1.6 16v sporting Shrick Fast Road cams. laaarvly.
will get pics after this weekends frolics
done today
undersealed rear inner arches after welding
undersealed welded engine bits
sprayed and undersealed the bucket seat mounts
removed old 180mm drums
fitted 200mm back plates and stub axles
fitted bearing races into new 200mm drums
fitted handbrake lever and front part of handbrake cable
fitted wiper mech - need the clips, nuts and grommets to attach the spindle bits tho if anyone can help
ate donuts drank irn bru and got baked <3
tomo
keys
coupe s wheel
get brake lines made up
buy - 2 rear flexis, 1 wheel cylinder,handbrake cable
circlip for brake/clutch pedal x 1
cirlip for throttle cable x 2
dremel rounded rear brake line
fit rear drums, hb cable, brake lines
fit front calipers/discs/flexis
fit pedal box and pedals
steering column UJ
gear lever
fit wiring loom
studs for seats and fit
got 28 days till the unit gets turned into a helicopter pad =/ so thats my deadline to get it running and out of there, if anyone wants to come grab some free/cheap parts to save them from mr scrapman, pop over
wouldnt mind a helping hand too =D
anyway engine loom found in the unit, main earths connected and fusebox screw in place, battery fitted.
badly need the nuts and grommets for the wiper mechanism, anyone got any kicking about
6,7,8 wiper locknut and washers and any plastic or rubber gromets
pics of seat mounted, pedal box and steering column fitted.
although i broke the clevis pin, so if anyone has one?
6a and 6b clevis pin
12 cirlcip
engines internals cleaned, sprayed down, drained and wd40'd up, sump bolted on to stop dirt getting in, but not cleaned up the mating surfaces or gasket pasted them up yet.
just need a waterpump and i can get the tensioners fitted, head on and cambelt fitted. then i need to get hold of a 5 speed box, or just bolt ad's 4 speed in as a quick fix
finally found all my hub mounting bolts so the front brakes are on - lucas 54 calipers, ferodo ds3000 pads and ebc discs
200mm rear drums and v dutty powdercoated rear axle, still awaiting my rear handbrake cable, when thats here i can get the bearings fitted. gotta order me wheel cylinder and brake lines tomo, but still desperatly need a clevis pin pedal pushrod thing for the master cylinder and the MC spacer. should also get hold of an uprated suspension kit for the rear as these shocks are truely pwned but should be mot'able for time being
grille and lights fitted, bonnet just rested in place, got another black one but need to get the vent holes are the rear welded up
trial fitted top fill rad, unfortunatly its gonna require some slam panel butchery, i think rather than just messily cut it out, i've got various hole saws, so ill make a circular cut out big enough to pull the cap out from and notch the inner part of the panel so i can get some grippy action around das cap. id rather retain as much of the original slam in place for fear or it collapsing!
note the grille cut out in this pic, im going drill the panel behind it, and fit an air scoop as fitted on GT's iirc and feed that over the carbs, eventually getting round to sorting out a plenum chamber for them
random pics
then spent the rest of the time sorting out bits in the unit, getting rid of pap ill never need, and boxing up the rest ready for an ebay flex.
heres what i uncovered from the house alone, its all gonna go on ebay at 99p starts when i get round to putting them up (next week or two)but if anyone wants owt gimme a shout
Mk1 Golf
GTI Magnecor KV65 Competition Leads Red with 2 Cable tidys
GTI TSR Drilled Airbox
GTI K&N Panel Filter
GTI Warm Up Regulator 438 130 073
GTI Cam Pulley - 056 109 111A
GTI Lower Crank Alternator Pulley
GTI Water Pump + Near new thermostat+housing
GTI Near new Bosch Starter Motor 055 911 023B
GTI Drivers Engine Mount - Rubber needs replacing
GTI Rear Gearbox Mount + Rubber
GTI New Downpipe Gasket
GTI Complete Series 1 1600 Metering Head/Injectors/All Braided Lines/Fuel Filter
GTI Semi Polished Alternator
GTI Oil Cooler / Hoses / Mounting Brackets
GTI Series 1 Contact Breaker Dizzy - Near New Condensor & Contact Breaker 049 905 205E
GTI Series 1 Parcel Shelf
GTI Complete Series 1 1600 Head / Cam / Water Housing / Inlet Manifold / Throttle Body
GTI Short Driveshaft - Good condition, relatively new inner CV
Bosch Starter motor 055 911 023L
Gearbox Selector Shaft
New Tensioner Stud
New Linkage Rod Bush
Tintop 3Door Green Tint Glass Front Passenger/ Rear Drivers / Rear Windscreen
Tintop 3Door Clear Glass Rear Passenger
Polo
Mk1-3 Lower Strut Brace - Adjustable but ONLY for cars up to -40mm.
Mk2 Polo Coupe S Contact Breaker Dizzy - Near New Condensor & Contact Breaker 023 191 009 / 052 905 205
Mk2 Polo Coupe S Airbox/Filter/Elbow
Mk2 Polo Coupe S Exhaust Flexi Section
Mk2 Polo Coupe S Metal Cambelt Cover
Mk2 Polo Powdercoated Water Housing & Thermostat Housing 052 121 117 / 052 121 171C
Mk3 lower steering cowling cover 171 953 516B
Mk4 Polo 1.4 16v Power Steering Pump Pulley
Mk4 Polo 1.4 16v Power Steering Pump Pulley + Pulley
Mk4 Polo 1.4 16v Crankshaft Cambelt Sprocket
Mk4 Polo 1.4 16v - Plastic Dizzy Cover & Lead Tidy 036 103 565A
Mk5 Polo GTI 1.6 16v Inlet Manifold
Mk5 Polo GTI 1.6 16v Cylinder Head
Mk5 Polo GTI 1.6 16v Red Rocker Cover / Cams / Pulleys
Mk5 Polo GTI 1.6 16v Standard 4 Branch Manifold
Mk5 Polo GTI 1.6 16v Decat Downpipe
Mk5 Polo GTI 1.6 16v Flywheel
Mk5 Polo GTI 1.6 16v Engine Wiring Harness
Mk5 Polo GTI 1.6 16v HT Leads Red x 4
Lupo
Lupo GTI 1.6 16v Standard 4 Branch Manifold
Lupo GTI 1.6 16v Decat Downpipe
Lupo GTI 1.6 16v Hydraulic Clutch Release Cylinder 600 721 261A
Lupo GTI 1.6 16v Engine Wiring Harness
Others
VW Cable Change Conversion for Hydraulic Clutch Gearboxes
Coil used in Emerald Setup - 089 04B 00104 - Leads from top left, clockwise are 14,32,27,41
Audi 3 Pod 52mm Guage Facia - 812 863 321C
2.5" NOS Veglia Borletti 8 Bar Oil Pressure Guage
BMW Smaller, Lighter Power Steering Pump Pulley to fit Mk4 Polo 1.4 16v - 1715769
52mm VDO 150 degree Oil Pressure Guage
12" Slimline Fan
Opel Manta GTE Tartan Recaros
320mm Aftermarket Steering Wheel
Slimline Ali Rad 12"H 1.75"D 20.5"L 23.5" between mounting lugs
saturday
well productive day was had today,
we put nays mk3 polo back together after he took apart to change the headgasket and a few other bits, and i got to pilpher some much needed bits for the mk1, muchos kudos to nay
anyway bits done on the mk1
* rear wheel cylinders fitted both sides
* rear shoes fitted both sides
* got a nos handbrake cable but its such a random design, need to fathom it then i can fit it tomorrow
* new clevis pin fitted on the pedal box, all circlips in place and nos master cylinder fitted
* interior loom fitted
* dash fitted
* clocks/speedo cable fitted
* earthes fitted.
* made cut out for top fill rad
* mounted front number plate
* mounted both front seats
* fitted washers and locknuts for wiper mech and fitted wiper arms (well one, as the other has gone awol and they are mk1 polo specific!)
* bonnet catch and release lever fitted
* fitted new door seals
and the new oem shoes to keep with the lupo theme when i get hold of some tyres, if anyones got any 175/50 185/50 195/45 14 inch rubber lying around gimme a shout
picked up a new water pump today and getting at gt 5 speed box from dubmania tomo, so the engine should be in the car one evening next week, proper buzzing
list for tomo
horn + hornpush
full brakes lines + bleeding
relay - lights
harnesses
ignition wiring loom/coil/tca
power distribution block
rear number plate light and heated rear windscreen
list for week
rear beam bushes
water pump / cambelt
oil pickup/sump
flywheel/clutch
clutch release bearing/gearbox
crane
bonnet/bonnet stay
parts list
gearshift base
afh starter motor
thats enough to jog my memory for tomorrow
couple of crap pics
sunday
fitted full new solid line and flexis, solid lines from rear are 15cm and 40cm too short so will get some extra lines made up in the week
fitted brake pedal return spring
wired up coil and ignition loom
working rear electrics, unfortunatly told the welder to weld up the hole for the numberplate light wiring DOH! so will drill that out
fiited water pump / cambelt and timed up engine, will refit sump tomorrow and then the lump is ready to go to the unit.
need to pick up das GT box from hoppys in the week and then chuck the engine in there woop
