SamAtkinson
Wurring noise when driving. HELP PLEASE
When driving in any gear, as soon as you put your foot down just a little bit there is like a wuring noise, its hard to explain. It could even be described as a churping
There is actually a point if the accelerator is pressed below that level it will churp
It sounds like it's coming from the passenger side, but tghis could be because i dont have the door card on that side at the moment.
When out of gear there is no noise, at least not one that can be heard slowly climbing through the rev range
Any ideas?
I should also add that the passenger side wheel has some pretty bad anti camber that will be sorted soon but I thought id mention everything just in case
Thanks
Sam
What on earth is anti camber? Is it a constant noise or does it make the noise and then stop?
think u mean positive camber buddy, maybe driveshaft causing the noise as the drive shaft is prob not seated right due to camber, so when u put your foot down there is more tension on the shaft, just a guess, someone will put me right if im wrong,,,,,,,,,,,,,,,,
hahaha i meant negative, im at uni and im tired :P
I hope its just that, im sorting it out this week [crosses fingers]
only when putting my foot past half way down on the pedal
Any chance of a video/sound clip?
what happens on the morotway when you let off the accelerator?
Edited by Defcon5
harder to hear on the motorway because of the noise from the road but when coming off the accelerator the noise stops
I'll find a camera and go out in the car tonight. Its in any gear when ever I put my foot down
I have this on my Arosa, riding the clutch slightly results in a slight noise hard to explain. I have been told what it is but i've forgotten.
Please remember :)
Please remember :)
I'll find out tomorrow and i'll let you know :)
cheers buddy, goodluck it aint anything to serious,,,,,,,,,,,,,,,,,,,,
It's the Clutch Release Bearing, over time they get dry and make the noise. It's worse in the cold weather aswell. It isn't too serious but you might need to get a new clutch one day although i've been told it's nothing to worry about until you get real clutch problems ( Pops out of reverse, hard and cranky to get in to all gears )
Hope this helped :)
Brad.
Hope this helped :)
Brad.
Hahaha my clutch does all of that now, well not really but its a pain
Im sure its a squeeking coming from the left hand wheel, had the window down last night and it was canny loud. Couldnt manage to take a vid on the phone of the noise but will try again with a camera soon
Sam
If the noise stops when you let off the accelerator, it can be the wheel bearing. Sure its not coming from the gearbox?
It sounds very left side-y
But it could well be
Sorry I meant it cant be the wheel bearing! :lol:
Indeed, can't be wheel bearing if it only happens when accelerating or when you have the clutch down.
My mate wheel bearing only made a noise when he got about 50mph, not sure if this is the norm or not?
Dunno why I've added that bit above because I don't think it's the wheel bearing anyway because in my experience wheel bearings (when they are broken) sound like when you were little and you'd stick a plactic bottle in the back wheel of your bike so it made an "engine noise" ... lol
mine does it when it's cold and it about 40mph or 50 or 60mph,does it for a while and then stops. it makes like 'uuuuuuuuuuuuuuu' noise :)
never knew what is it? does it for over 1 year
Okay, so we dont think its the wheel bearing. Im going to get get the wheel camber sorted and cross my fingers
Inspect the whole axel
I dont think it does make the noise when the clutch is pressed but its quite hard to tell
Tried recording it last night but its turning out to be a nightmare, need to get a hold of a propper camera see if the sound comes out any better
Sam
Any news on this problem Sam? I have had the same on my gti, but neither myself or the vw specialists i take it to can get to the bottom of it!
I have also tried recording the noise but it never comes out clear...
Dazz
Edited by Dazz
Some more investigation will be going on soon
Car will be jacked up tomorrow night for a serive and a good inspection
Is the steering wheel shaking when you get between 50-70 if it is it maybe the wheel bearing / hub thats what happened with mine might sum help if you jack it up and check for play in the wheel
mine shakes slightly but nothing too bad, will find out on sat hopefully!
i think i am having the same problem.....really want to get it sorted becasue its starting to do my head in :(
if you work out what it is, let us know :)
