la_la_lupo Posted November 11, 2009 Report Share Posted November 11, 2009 Hi allI need some knowledgeable help! My remote key has stopped working, when I press it it doesn't lock/unlock the car, I have to manually turn the key in the lock. This is fine from the drivers side and the key starts the car no problem, but if I open the passenger door or boot it sets the alarm off. The alarm stops when I start the engine. Does this mean I just need a new battery in my key or could it be something worse? I didn't want to go to the expence of having VW charge me to look at it if it is just a new battery.Thanks for your help!Amy x Quote Link to comment Share on other sites More sharing options...
jgaskham Posted November 11, 2009 Report Share Posted November 11, 2009 Does the light on the key work when you press the buttons? If not you need a new battery, i just replaced the one in my Arosa key and that was a CR2032 one. Quote Link to comment Share on other sites More sharing options...
la_la_lupo Posted November 12, 2009 Author Report Share Posted November 12, 2009 The light flashes once for a millisecond, as if it tries to work but can't. I'll try a new battery and if it doesn't work it might be a trip to VW...Thanks Quote Link to comment Share on other sites More sharing options...
jgaskham Posted November 12, 2009 Report Share Posted November 12, 2009 Have you tried recoding the key to the car, think it says how to in the how to make a flip key post. Quote Link to comment Share on other sites More sharing options...
la_la_lupo Posted November 12, 2009 Author Report Share Posted November 12, 2009 Have you tried recoding the key to the car, think it says how to in the how to make a flip key post.I don't think it is the code, if it was it wouldn't start the engine. When we bought the car the spare key didn't work, cause the kid had never used it, it needed recoding. It would unlock the doors but not start the engine. Quote Link to comment Share on other sites More sharing options...
99hjhm Posted November 12, 2009 Report Share Posted November 12, 2009 I don't think it is the code, if it was it wouldn't start the engine. When we bought the car the spare key didn't work, cause the kid had never used it, it needed recoding. It would unlock the doors but not start the engine.Check the re-programing instructions in your manual, fit a new battery also. It's not the key that needs recoding, it's the fob.If the instructions in the manual fail, and you have two keys.....First off, you require 2 keys to do it without a diag tool or your wasting your time. 1. Put 1 key in the ignition and turn the ignition on. (this way the car knows its got a known key in it and is happy) 2. Close all the doors and boot. (The car hates getting a chill and you need to keep it happy) 3. Put your other key in the drivers door and manually lock the car. (Remember the car is happy as it has a known key in the ignition and now you have a second key and manually locked it, it still knows its safe and will accept a new remote signal) 4. Press the button on the remote and you will hear a 'chirp' of acceptance. (This is the car letting you know its delighted to have another remote signal stored) 5. Manually unlock the car. (So it knows not to accept any other signals) 6.Turn off the ignition remove the key, close the door and confirm operation of the remote. 7. Your now as happy as the car Quote Link to comment Share on other sites More sharing options...
jgaskham Posted November 13, 2009 Report Share Posted November 13, 2009 ^^ thats what i meant to do, not the immobiliser coding, hope you get it working. Quote Link to comment Share on other sites More sharing options...
la_la_lupo Posted November 17, 2009 Author Report Share Posted November 17, 2009 Thanks guys, I'll give it a try. Put a new battery in at the weekend and it is still the same. Little scared about locking the car with the engine running, what if I can't get back into it??! Quote Link to comment Share on other sites More sharing options...
99hjhm Posted November 17, 2009 Report Share Posted November 17, 2009 Leave the window down. Quote Link to comment Share on other sites More sharing options...
Mickey Posted July 15, 2016 Report Share Posted July 15, 2016 (edited) any further advice on this topic ?? lupo gti i have two keys and have tried the above method many times using both keys in the ignition - i cant seem to get any response from either key when pressing the lock button after locking the door with the drivers side door lock put new batterys in both keys today and still no response any advice is appreciated thanks Edited July 15, 2016 by Mickey Quote Link to comment Share on other sites More sharing options...
