Dan's Grey Lupo *now up for sale*
dj_lupz
Ok guys cheers, so looks like i'm stripping back the bumper for a 3rd time but i'm not 2 fussed coz i'm learnign in the process, which was the whole point off the project to experiment and learn.
I use plastic at uni so i'll get some.
what thickness would you recomend?
I've got sum in my room i'm using atm and the 2mm looks the best. a bit
People want to see this done and done to a cool standard so thats why everyone is chipping in! B)
for sure! its good and always learn from your mistakes! :P
You should try to use a similar material to what you're working with, so the ideal plastic to use for smoothing bumpers would be plastic from another bumper.
exactly! that way it will be a real like for like match!
hummm
i'll need a front bumper then.
but surely if i cut a bit out off a standard bumper on ither side off the plate recess it won't be right because it is less curved just before the plate recess and i'm guna need like 50 cm+, so total like 25cm+ ither side of the recess.
And one know what type of plastic the front bumper is coz i can get different types of plastic, from uni.
cheers for all the advice i'm be making some rigth cock up's with out you guys.
:P
hummm
:P
if your doing a product course at uni you should be able to tell what kind of plastic it is,,,, :P
its most probably poly prop or some form of polyprop due to its flexibility and sorty of waxy feel(thats how you tell what PP is)
  • 1 month later...
Not up dated this in ages, but not really been able 2 work on it with uni.
but home for a few weeks over easter so will get workin on it.
Only real up dates are;
new dash
passanger wing mirror
front indecator panle
standard steerin wheel
new front components (should be here in next couple off days)
Also decided which sub and amp's i'm getting.
And my colour and material scheme
and sort off have an idea the boot area but not 100%
There should be some updates coming soon,
as i've been doin a bit off work on the car.
got my mates bro to come have a look around it some time in the next couple off weeks, who works in a body shop.
small up date,
front bumper nearly finished and i'm happier with it now..
will get pic's soon when its finished.
New front speakers
Smooth front indecator pannle
1st cut out the shape in ABS plastic the used a solering iron to melt it then fillered over
this was my 1st attempt on my old front pannle.
i have a new one which will be smoothed soon.
more interior bits
custom tweeter build
started off by desiding which angle i wanted it at then, then shaped a form wedge so the tweeter housing sat right, glued it so it would stay in place.
then raped it in material and fiberglassed it, and fillered.
gettin there just givin it its final fill, and will sand and primer it up 2 mora..
Edited by dj_lupz
Some pic's from the other day when i took her out the garage :)
Been working on the front and rear bumers 2 day getting them perfect..
also a bit on the right hand side filling...
anyway some pic's from when she came out the garage...
I can just about see the turning point now..
once body work is all primered up, stuff will start goin back in :D
Btw can anyone recomend a good company to buy material for DIY retrimming in the leeds area ???
Cheers
Edited by dj_lupz
  • 3 weeks later...
A little up date front bumer is prity much finished now and i'm getting happier with it.
Front indecator pannle smoother.
started by sanded the paint back to the plastic then plastic welded in two circles into the holes and then fiberglasses over then sanded and filled over.
done!
Oyeh for got some goddies arrived a few weeks back :D
Edited by dj_lupz
