Tigz™ Posted September 14, 2004 Report Share Posted September 14, 2004 OK I am on strike still but like the firemen, in emergancys I guess I can be called out Ok the bandwidth ajust is a tricky thing to try and explain.Erm.. Lets say you boost the frequency at 100hz by +3 with the bandwith wide. This will give a more boomy sound.This is what will happen to each frequenciy.140hz by 1db120hz by 2db100hz will be ajusted by 3db 80hz up by 2db60hz by 1dbIf you looked at it on a chart it'll look like a steady hill clime up, then back down.If you set the bass the same, but set the bandwidth narrow when you'd look at the chart it'll look like you were climeing up and down a light house.This will be more precise.I dont really understand it enough to explain, but if you have a look herehttp://www.talkaudio.co.uk/vbb/showthread.php?t=46019It explains a little on what each frequencie does, so it'll make it a little easier to set it up. Quote Link to comment Share on other sites More sharing options...
DanGTI Posted September 14, 2004 Report Share Posted September 14, 2004 read the words of the ICE geek on that link.....i understand it now. thanks tigz Quote Link to comment Share on other sites More sharing options...
Tigz™ Posted September 14, 2004 Report Share Posted September 14, 2004 any time mate. Quote Link to comment Share on other sites More sharing options...
