tttttada
Tada's GReeeeN Lupo GTI - Last update 1.11.2014
Did some researching, and it seems that I'm SOL for a LSD.
Time for some headwork.
1) Schrick 256/252 cams
2) Exhaust ports matched to the Raceland mani and polished.
3) 2nd remap
Will be done within a 2 week timeframe.
I'll keep you guys posted.
3) 2nd remap
I would go for more aggressive camshafts than that for a race car. something equivalent to this with some springs and retainers would be ideal
Catcams 7606704 camshafts
Thanks for the tip.
This car is not a race car; my R32 is closer to it.
And I'm a Schrick dealer so it makes better sense this way.
Id like to hear more about your R32 aswell :wub:
Tom
It's got a whole bunch more but here's a short list
Power mods: 425HP turbo, titanium exhaust
Suspension: Moton dampers w/ resorvoirs, Hyperco springs
Brakes: Front and rear Alcon 4-pot calipers w/ 355mm rotors
Drivetrain: Front and rear Peloquin LSDs
Chassis: 12-point rollcage
Edited by tttttada
never noticed this before but the lupo really does look like a squished mk4 golf from the side
Brilliant! :wub: love it!!
how much did your wheels cost and where did you get them from.and really nice car
Thank you for your kind words.
I bought them in Japan so I'm not sure if it'll help, but they were 89000YEN (approx 470GBP) for four wheels
As promised, here are the rest of the pics of my exhaust system.
Raceland manifold prepared to be fully wrapped
2nd branch (4 ->2) cut and welded to clear oil pan.
Lengthened O2 sensor -> flexipipe -> sport cat
Edited by tttttada
Cam cover taken off for a full P&P and installation of Schrick cams.
Pic of intake manifold and gasket.
It seems that all the previous info about the intake ports were correct.
There is hardly any port matching to do on this side.
Probably about a millimeter all around.
But here is where it gets interesting.
There is a TON to be ported on the exhaust side.
Here are some measurements I took (remember the exhaust ports are oval shaped and are shorter vertically)
Gasket ports:
30.0mm(H) x 43.5mm(W)
Manifold ports (from left to right)
29.5mm(H) x 51.0mm(W)
26.5mm(H) x 49.5mm(W) <- WTF
Head ports:
23.5mm(H) x 32.0mm(W)
As you can see, when matched to the gasket, the exhaust ports can be ported 6.5mm in height and 11.5mm in width.
And when matched to the manifold another 7.5mm in width!!!! THAT IS HUGE!!!
(the Raceland manifold has one small port. Probably a manufacturing error.)
We are still debating on whether we should port match to the gasket or the exhaust manifold.
Will keep you posted.
Edited by tttttada
does that mean you can get me a set of shrick cams for my car nice and cheap :)
lovely car though... look forward to seeing progress
probably not with postage seems as he is in Japan :-)
The head came back yesterday.
As you can see, I ended up matching the ports to the gasket.
So the width is now 30.00mm (ported 6.5mm) and the height is 43.5mm (ported 11.5mm)
For those wondering, that is more than a 70% increase in port area, which is HUGE.
(area of oval = pi*a*b where a = half length of major axis (horizontal) and b = half length of minor axis (vertical))
before = 590mm^2
now = 1024mm^2
The valves were all pulled and chambers were also ported.
Had it gas-flowed, but decided against polisihing it.
Some engineers have told me that it doesn't make a difference, as far as flow efficiency goes.
At any rate, the head is on the car now and the Schrick cams are being assembled.
In the meantime, the exhaust mani has been wrapped.
After that, off to the ECU tuner.
Edited by tttttada
Will be good to see what the car performs like after all of this work
We added a duct to the CDA intake, and routed it to the lower bumper grill.
I'm hoping it'll lower the intake temperature.
The car came back from the cam install, and I test-drove it before sending it off to the tuner.
Bottom line: even without the tune, the car is MUCH faster
The midrange torque from 3000RPM is ridiculous, and it pulls hard until redline.
The flatness of power between 5.5KL-7K rpm is gone; the engine really wants to pull hard even past 7000+rpm.
I will tell the tuner to set the fuel cut-off point at 7500rpm.
Overall I cannot be happier of the results.
I was expecting some torque loss from the extra duration of the cams, but the P&P really set this engine alive.
I have high expectations of what the tuner can add to the output.
Will track the car on the 18th. Can't wait.
So, for those of you wondering, this is a highly recommended mod!!
do you know if that rear sway bar will fit on non gtis as it looks as if it is just bolted to the bottom of the suspension struts,and then two more brackets holding it in the middle
Sorry, can't help you.
I barely know anything about my own car. I've only had it for 3 months. :)
