Tada's GReeeeN Lupo GTI - Last update 1.11.2014
tttttada
Got the car last month and did the following.
1) G60 conversion with slotted rotors and Goodridge lines.
2) Enkei RPF1s 15x7 (4.2kg per wheel)
3) H&R coilovers
4) Jabbasport rear sway bar
5) In Dash Navigation with Camp2
6) Front Strut Brace
Hope to do the following this and next month.
1) Kam Racing Headers
2) One-off sport cat, and catback
3) BMC CDA Intake
4) Schrick Cams
5) Remap
How it sits now.
Camp2 module showing Water temp and Oil temp.
-2.5 camber for track use
Hope to update this thread as the mods progress.
Edited by tttttada
That temp reader is awesome, where does it get the figures from?
It gets all the readings from the OBDII port.
Water temperature, Oil temperature, Oil pressure, Battery Voltage, Engine speed, A/F ratio, Gas Mileage etc etc
I was a little skeptical about the OBDII readings so I got optional Water and Oil temp sensors and plugged them
directly into their respective locations (right before radiator and oil pan plug) However, the readings were only
off by 2-3 degrees Celsius.
Good one mate...!
Tell me a thing...!Why did you put the catch tank pipe on the CDA curve...?Isn't better a little BMC filter...?
D.
Maybe something to do with keeping the vacuum?
For me is not god...!
When I fitted the CDA I put a little filter directly from the engine pipe,the one that came from down...!
Instead installing the catch tank I think that this filter should be fitted on the upper part of the tank without fit the pipe to the curve...!
Hope you'll understand what I mean...! :lol:
D.
Looking sweet Tada!!!!!
Whens it hitting the track?When you do can you get some vids and pics
Thomas
I've hit the track 2 times already in this car.
Next time up is this Saturday.
I'll have an onboard cam for the Golf Cup on August 31st.
where did you get your catch tank pipe's from and the catch tank from ??
Ry
Both from a vendor in Japan. Sure you can find one local.
What is benificial about that then? What does ut actually do?
You've got to realize why Volkswagen designed this engine with a blow-by valve in the first place.
Blow-by gas is left-over gasoline. It corrodes engine oil and therefore deteriotes engine performance and efficiency.
Wouldn't you want that out of the crankcase, back into the cylinders, fully combusted, and out through the exhaust?
If you don't have vacuum you might as well leave the engine as is, without a catch tank.
Defcon5,
If you were asking what a catch tank does, it collect the corroded oil and moisture within the crankcase.
Only the blow-by gas (that causes carbon and sludge build-up) returns into the intake.
very nice... now i understand what one of those does.
How hard was it to put a hole into the bend? and what did you use to plug it with? Just the pipe itself?
It wasn't hard at all.
We first measured the inner diameter of the catch tank tube, and made an aluminum tube with a flat base.
We then cut a hole in the silicone hose, and pushed the aluminum tube from the inside of the silicon hose.(the base has a bigger OD, so it doesn't pull out)
Finally plugged the catch tank tube, and applied some clear silicone epoxy.
Revved it to 6500RPM with no sign of intake leak.
How was it? Did you do ok?
Will look forward to seein some vids......
Good luck for this saturday!
