VWR Lupo
The definitive Gearbox thread
Just changed the 18 month old tractor diff oil (straight mineral EP90 GL5 because it was whiney) back to fully synthetic 75EP90 GL4-5 as it's easier to change gear when the oil is cold.
After a year and a half (15k miles) this is what I found on the little magnet I stuck inside the sump plug (in addition to the built in magnet you cant get to). Gives me an idea that all is still ok- no major chips- just very fine black dust. Also the oil came out nice and clean which is a bonus.
I'm still going to rebuild it when I get a chance. 90k miles and counting on my SDI no.1.
On 21/08/2015 at 11:03 AM, Sausage said:
The only real way to overfill it is while it's off the car before refitting it.
You can fill it the old way through the speedo pickup :)
Or jack the front of the car up.
hello there guys. i have a 1.4 lupo e. the gearbox has a bad, loud grinding noise when in neutral. if i put my foot on the clutch pedal the noise goes immediately but foot of the clutch pedal its back. i bought a clutch release bearing and want to change it myself. what i want to know is doi have to drain the oil or i can do it without drain it as i have no idea of where to do it from. can somebody help me out here please with a guide. thanks.
No need to drain oil.
Remove start motor (3x13mm head bolts)
remove driveshaft bolts (12 in total - think they’re size 10 , definitely triple square / spline though)
4x 18mm head bolts hold it to the block
drop box out (it will clear the subframe and driveshafts with a bit of wiggling!)
replace thrust bearing.
Installation is repeat of removal.
Probably not your release bearing (unless clutch is out of adjustment), more likely bearing in gearbox.
Slowly press the clutch pedal, listen and also feel with your foot, when does the noise change? Slowly release clutch, now where does the noise come in?
You dont have to drain the box to remove it as said above as it has drive flanges which seal it, but to be honest you would be better off cracking off the fill (do this one first!) and drain plugs in situ (as they can be hard to undo with the box off the car) and draining it into a tray and shining a torch into the oil and looking for metal particles before deciding to drop the box.
sorry to drag this up again, can anyone recommend a company that you have used in the past to rebuild the gti 6 speed box that charges a reasonable price. I am based in Grimsby (DN36) so the closer the better but i dont mind travelling a little if i have too.
