gti brakes unacceptable?
willcrook
i've never had a problem with the standard brakes. i had a Pug 306 rallye and that was fine with standard brakes but i fitted EBC dics and pads and they were crap. i also have a mini and the brakes fade every time i go for a drive.
if you have had brake fade are you using VW discs and pads?
Mine are awfull, I do go for long very spirited drives though....
The brakes fade very quickly, the stopping power is reasonable...
If I knew I was keeping the car i'd invest in a NO EXPENSES SPARED brake setup! :) (wilwood? :P )
(I wrote the topic last night after a long blast in the countryside, was a great drive but the brakes pissed me off again!)
I nearly crapped my pants the other week whilst having to stop racing some kind of escort.
They're not the best and I've got standard discs with greenstuff pads all round.
yeah i've been looking at the willwood 256 conversion but they only do it to fit 256x20mm disk with the mount for a mk2 and i'm not sure if the spacing is the same. anyone know?
ive done the 280 mm conversion.. id like to go a bit bigger but purley for cosmetics.
at first i used the green stuff pads with black diamond grooved discs but they didnt really bite properly.. although it was a massive improvement over the standard set up..
i then switched to mintex extreme pads and the brakes spot on at the moment. guess its all trial and error for whichever combination of pads and discs to suit you.
and... are they any good?
or are you just bragging?
do you have led lights on your alloys or are they glowing with heat? ;)
The picture says it all.... obviously.
no led's req'd - LMAO
this is no Halfords pimp mobile
Inside the car, racing around Oulton Park, you would be oblivious to the glowing disks such was the consistency of the braking and pedal feel.
:shades:
256mm Lupo GTi brakes suk. Faded like a pig, overheated.... and did not stop it so well.
This car used to also run 305mm Brembo 4-pots which was seriously overbraked for such a small & light car.
The 280mm setup worked much nicer as a package, combined DS2500 pads and high temp motul brake fluid. (as per my ibiza racecar)
Good enough answer for you?
Edited by badger5
280mm G60/Ibiza Cupra front setup
Running Ferodo DS2500 pads and Motul RBF600 fluid... disks are eliptically grooved Brembo ones. (brembo disks I get grooved)
Are you using just cupra carriers? to run 280discs or the full set up??
