Silver!'s GTI
Silver!
14 hours ago, Blue Loop said:
You will have a blast through those roads up there... make sure to take some pictures!
Yes I sure will. I have done most of them before, just not in a single trip. Will be taking it easy as I will have the dog rattling around in the back.
R
R
Good! Enjoy!
  • 1 month later...
On ‎18‎/‎05‎/‎2016 at 7:44 PM, Pete said:
Because you're getting out and about and not stopping by my ends.
Slightly in the wrong direction Pete.
3 hours ago, Blue Loop said:
Nice one!
No exterior pictures tho :(
No, it's absolutely minging at the moment. Needs a good clean :huh:
6 hours ago, jon_273 said:
Fail for not having the original plastic cable holder for the ABS cable. KW went to all the trouble of welding the tabs on in the right place too... :coffee:
Pics? Part number?
7 hours ago, mattarosa said:
Have you cut that cable tie off flush ray? If not shame on you!
Nah, I left it long so it clicks on the wheel spokes; ala playing card on my Chopper back in the 70s :roflmao:
  • 1 month later...
On 30 June 2016 at 11:01 AM, Silver! said:
New KW v1 Inox fitted. Need some tidying\remedial work under there soon.
Shite photos, but it needed to be done...
First things first, lovely car Sir :) Having just scanned through this thread I'm really impressed with the amount of time and effort you've put into this!
One question I would ask is when looking at the shock mount/beam-end in the picture above (First pic), doesn't the level of corrosion there worry you? Mines much the same, and whilst I know it's good thick steel I can't help but hatch plans in my head to buy a spare and have it blasted/powder coated or at the very least rust treat my existing beam in situ...
Exactly what  am in the process of doing. I have sourced a beam and will be picking it up in a couple of weeks.
Then to get it stripped, treated and powder coated and swapped over. Most likely next spring.
Good crack :D
Silly question... Are all Lupo rear beams the same irrespective of model?
58 minutes ago, JoeyEunos said:
Good crack :D
Not sure. You'll have to ask someone else. Sorry.
2 hours ago, Silver! said:
Just spoke to Rich; all beams will fit a non GTI and work, but there are differences.
Thanks chap ;) FWIW I ended up getting busy with my existing beam this morning...
More info on this in my 'member's cars' thread, but in short after a rub back there was little more than cosmetic/surface rust, I'm confident that now it's been treated the original beam will last for the rest of this cars life without any problems.
