Information: The Part Numbers Thread
  • 4 months later...
SERVICE PARTS
1.7SDi's 99>00 engine number upto 6XY060000*
1.7SDi's 00>02 engine number 6XY060001* on
Oil Filters
All Petrol Models - 030 115 561 AB
1.7SDi - 030 115 561 C
1.4TDi - 071 115 562 A
Air Filters
1.0 AER - 032 129 620
1.0 AUC - 030 198 620
1.4 16v , 1.6 16v GTI - 036 129 620 F
1.7SDi 99>00 - 6N0 129 620
1.7SDi 00>02 (6XY060001>>*) , 1.4TDi - 6N0 129 620 A
Fuel Filters
All Petrol Models - 6X0 201 511 B
1.7SDi 99>00 - 6N0 127 401 R
1.7SDi 00>02 , 1.4TDi - 6N0 127 401 H
Spark Plugs
1.0 AER - 101 000 036 AA
1.0 ALD/AUC, 1.4 16v AUA - 101 000 062 AB
1.4 16v AHW/APE/BBY/AUB , 1.6 16V GTi - 101 000 033 AA
Wiper Blades
GTi LH - 1J2 955 425 B
GTi RH - 6x2 955 426
Non GTi front pair - 1J0 998 003
Cables
Clutch cable 1.0, 1.4 16v, 1.7SDi - 6N2 721 335 B
Handbrake cable - all with rear drums - 6X0 609 721 H
Electrical
Alternators
1.0, 1.4 16v, 1.6 GTi Bosch 70A - 038 903 018 SX
1.7SDi Bosch 90A - 06B 903 018 SX
Starter motors
1.0 - 085 911 023 JX
1.4 16v manual - 036 911 023 SX
1.7SDi 99>02 - 085 911 023 KX
1.4TDi 02A 911 024 DX
Wiper motor
Front All models - 6X0 955 119
Heater motor
All models - 1J2 819 021C
Lighting
Non GTI Headlamp LH - 6X2 941 751 J
Non GTI Headlamp RH - 6X2 941 752 J
Tail lamp LH - 6X0 945 095 D
Tail lamp RH - 6X0 945 096 E
  • 4 weeks later...
"intermittent piece" (lol) Part number W1J0 857 725
Goes between two din units to hold them in place.
This is now W1J0 857 725 B wink.gif style="vertical-align:middle" emoid=";)" border="0" alt="wink.gif" />
Edited by T5POL
  • 4 months later...
  • 3 months later...
1.4 TDI Airflow Meter - 045 906 461 X
£75.10 + vat Retail
£55.39 + vat Trade Club
Front Indicator light unit (near grille)
Left - 6X0 953 049G
Right - 6X0 953 050G
Edited by Tigz
  • 3 weeks later...
Info required to fit a Pollen filter housing and pollen filter to a Non GTI / Non-Aircon vehicle.
Part number 5 is a gasket that goes between the filter housing and the blower assembly...
5's part number is 6N0 819 165A
Part number 53 is the nut you will have removed to get the old "mesh" cover assembly off, you should still have this left over, but you will re-use it to attatch the filter housing. If you've lost it...
53's part number is N 90352101
Part number 20 is the cover, as you can see in the pic below...
20's part number is 6N2 815 645
Part number 15b is the frame that holds the pollen filter in position...
15b's part number is 1H0 819 648 A
Part number 15a is the Pollen filter itself...
15a's part number is 1H0 819 644
Part nuber 16 is the actual filter housing...
16's part number is 6N2 819 640 B
5 Gasket - This comes already bonded to the underside of part number 16 (housing).
An image of what the bits all look like before being fitted to the car
And an image once fitted to the car.
Note: If you wish to fit a Charcoal activated filter, according to the ETKA system, you will need a different frame...
Part number for the charcoal activated filter instead of using 15a is 1J0 819 644
and the part number for the slightly different frame is 1J0 819 648
The Charcoal activated filter helps to stop strong smells getting into the cabin and also helps to neutralize any allergens in the air entering the cabin!
However with some of the aftermarket filters, it is possible to use a charcoal activated version of the standard filter, thus meaning you can use the normal frame...
Edited by nfbr
more part numbers...
Sound absorbing foam - Door Membranes
Upper Left - 6X3 868 507G
Upper Right - 6X3 868 508G
Lower Left - 6X3 868 511K
Lower Right - 6X3 868 512K
Sealing compound for fitting foam membranes - D469 101 A3
Touran / Mk6 Polo / Mk5 Golf rear wiper assembly
6Q6 955 425 A (blade)
6Q6 955 435 B 01C (cap)
6Q6 955 707 A (arm)
I got a polo rear wiper for my car years ago, but it was a faff anout trying to cut the blade to size.
The polo blade is ok for lupos, however it does overlap slightly, but the arosa has a smaller rear screen so its more of a problem, and to cut it down is a bit of a chew.
So i found that a 2007 Passat Estate has a smaller rear wiper but the same style (looks just the like polo one).
Its the same length as the standard lupo wiper, so it doesn let you see anymore, but it does look much much better and this shorter one saves the hassle of trimming down the blade to fit.
So as mine has been on a few years it was starting to go funny and judder on the window and since i used it a lot i thought i should get a new one, but i couldnt be bothered to cut a new one.
So i found this, ill take a pic if anyone wants one but its just the same as the polo one that seems apopular little addition, but smaller.
Part number: 3C9 955 425
Price: £5.63
So i thought id post it up as it may help some people
Chris
I don't have permission to post in the Part Numbers thread... So, for reference:
6H0 941 699 A - Lower Front Fog Lamp, Left hand side x 1
6H0 941 700 A - Lower Front Fog Lamp, Right hand side x 1
N 017 762 2 - H3 Halogen Light Bulb x 2
6H0 805 903 A B41 - Lower Front Spoiler x 1
1J0 973 722 - 2 Pin Flat Connector Housing x 2
N 104 269 01 - Spring Clamp x 4
N 104 271 01 - Spring Clamp x2
Are required to fit fogs to the front of your Lupo. Costs £139.02 +VAT.
You can use your existing switch, and both front and rear fogs will come on at the same time, when you pull the switch out.. Or you can buy another 2 click switch - Front fogs come on first, then both come on.
smile.gif style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" />
  • 3 weeks later...
Hi mate as i cant post on the part numbers thread i fort i would pm you instead.
the number i got is:
P V6EO 953 123
not sure if the 'P' is part of it or not.
its a front indicator (not side repeater the one under the dipped light in the same unit) bulb holder made by valeo.
around £4.00
Cheers
Lu
  • 4 weeks later...
  • 1 month later...
Passenger Side Stubby Mirror Glass
W6N2 857 521 B
£21.44 + VAT
Internal Bonnet Release Handle in Dark Grey/Black
W6X2 823 633 B
£5.96 + VAT
Bracket That Sits Behind Internal Bonnet Release Handle in Dark Grey/Black
W1J2 823 533 CC 81
£2.11 + VAT
Driver Side Door Check Strap
W6E0 837 249 C
£12.70 + VAT
Pin For Door Check Strap
W6E0 837 257 A
£0.34 + VAT
Track Rods
you can get the ends separately
part numbers
o/s 6x0 422 812 £20.76 inc vat
n/s 6x0 422 811 £20.76 inc vat
i'd also recommend changing the nyloc nut that fixings them in place
n903 213 02 £0.60p each inc vat
  • 4 weeks later...
503k45l.jpg border="0" class="linked-image" /> border="0" class="linked-image" />
524676794_09b0c32256.jpg border="0" class="linked-image" /> border="0" class="linked-image" />
DIN Cupholder
W6X0 857 558 A
Hey mate.
I got part numbers for Aero Wipers for the GTI (these are the ones that you dont need to buy new arms)
6X2 955 426 A
1J2 955 425 B
Thanks
Lupo*
Hi,
got the part number for an electric window switch. Its from the drivers door so its got 2 clicks, one for puttin your windows down whilst holding the switch down and the second click for automatic.
6X0 959 855 B
http://img103.imageshack.us/img103/8445/dsc02141ml7.jpg
Cheers, LupoLu
  • 3 years later...
Sent an enquiry to VW today for a few parts, just wanted to chuck them up, i think some are already on here:
For the rear aero wiper (i'll put up a how to, if there hasn't been one)
6Q6 955 435 D - POLO WIPER 'CAP' - £2.28
6Q6 955 707 B - WIPER ARM - £16.31
3C9 955 425 - POLO WIPER BLADE - £7.04
£25.63 INC VAT for the above.
Service parts:
201 511 B - FUEL FILTER - £10.14
030 115 561 AN - OIL FILTER - £5.06
WLST 0M2 RZX - MOON SILVER TOUCH UP PEN SET - £6.03
WLLS 0M6 RZX - MOON SILVER SPRAY PAINT SET - £13.09
Lupo GTi bumpers:
6E0 807 217 J - FRONT BUMPER - £91.38
6E0 805 901 - FRONT SPOILER - £60.54
6E0 807 417 B - REAR BUMPER - 106.29
Hope it's of some help
Mark
  • Like 3
  • 1 year later...
Hi there was just wondering is there a full list any where on the forum of parts numbers
if not I was thinking maybe Lupoboz could provide one
Edited by marky82
