Rear Lights - how to remove
open the trunk
look for a screw keeping the light cluster into space, it's a big, black one; you can use a `flat-blade` screwdriver or a torx one, once you've done that, you can gently pull the light cluster sideways (towards the outside of the car). Dont pull too hard, there are 2 pins that keep the cluster still in place.
