Snowball Posted January 10, 2007 Report Share Posted January 10, 2007 Hiya peeps...Just a quick question:Is it possible to just top up the oil in the engine, even if the oil is different? Are there any major drawbacks to doing this?My oil is dangerously low, and no garage near me could do it today, so was thinking of just topping it up till it has it's service (in 2000 miles time).Thanks in advance style="vertical-align:middle" emoid=":)" border="0" alt="smile.gif" /> Quote Link to comment Share on other sites More sharing options...
Joe Posted January 10, 2007 Report Share Posted January 10, 2007 Should be fine yep.just top it up, but don't over fill it Quote Link to comment Share on other sites More sharing options...
lupogtiboy Posted January 10, 2007 Report Share Posted January 10, 2007 you just need a decent 10w-40 oil, something like castrol will do! Quote Link to comment Share on other sites More sharing options...
seanmooney17 Posted January 11, 2007 Report Share Posted January 11, 2007 if the car does not use 10w-40 and you put in a different oil will it not do dammage, a mechanic told me it can mess the engine up if two different oils are mixed. Quote Link to comment Share on other sites More sharing options...
Joe Posted January 11, 2007 Report Share Posted January 11, 2007 If its serviced as per the VW instructions it'll have 10w-40, bt I doubt very much it would make any difference mixing grades Quote Link to comment Share on other sites More sharing options...
cardaft Posted January 11, 2007 Report Share Posted January 11, 2007 (edited) Why not get it serviced earlier? its supposed to be every year or 10K isnt it, i do mine about every 6K - 7K and use a flush each time, so its never dirty, even in the diesel its still clean after 5K now.Its usually best to top up with the same oil that is in already, but i dont really see it making much difference, aslong as its the right VW spec grade of oil you use.If its really low then it must be using oil?Chris Edited January 11, 2007 by cardaft Quote Link to comment Share on other sites More sharing options...
Gavs_arosa16v Posted January 11, 2007 Report Share Posted January 11, 2007 To be honest it will do more damage not having any oil. If its getting changed soon nothing to worry about.Mine drinks quite a bit of oil when its due for a change. Quote Link to comment Share on other sites More sharing options...
