How to: Wheel Clean Guide
- Start with one dirty wheel
- Then prepare yourself with the following items
Newspaper for when the wheel is face down
Wheel cleaner
Tyre cleaner
Bodywork / Wheel wax
2x Jugs of water
Wheel cleaning brush
Old towel
Some cloth or bits of old t-shirts
Can of your favourite drink
Now you will need to jack your car up and remove the wheel
Start with the inside of the wheel
Spray the wheel with wheel cleaner
Then work the wheel cleaner in with a brush
When you've fully brushed the entire wheel rinse the wheel off and do the same to the outside (face) of the wheel
Once again rinse it all off and dry with a towel
Now that the wheel is towel dried, Get your wax out and cover the wheel with a light but not shy coat of wax and work it in with a cloth or bit of old t-shirt in circular motions
Next you will need a new bit of t-shirt, once the wax has dried to a hazy finish to polish the wax off
And their you have it, One super clean wheel
A quick note, If you have split rims, diamond cut, chrome or polished wheels... avoid use of wheel cleaning products, Instead use hot soapy water and a bit of elbow grease :)
Edited by nfbr
Cleaned by: nfbr.
This topic is now closed to further replies.
