cj1 Posted November 5, 2018 Report Share Posted November 5, 2018 Clunking randomly over bumps etc and then noticed this when I stopped. And a weird whirrring sound when turning heavily to the right. At first I put the clunking down to the diff that’s in the car but seemingly not! Not had time to properly inspect, but sounds like a ball joint, right? A2FA1568-5F4C-483B-A84E-C2A9FA4EFF25.MOV Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 5, 2018 Report Share Posted November 5, 2018 Yeah, rack? Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 5, 2018 Author Report Share Posted November 5, 2018 I would have been inclined to think that also but I’m not too sure. It seems to clunk in a straight line too with no steering input. Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 6, 2018 Report Share Posted November 6, 2018 Top strut bearing? Quote Link to comment Share on other sites More sharing options...
Sausage Posted November 6, 2018 Report Share Posted November 6, 2018 Cant see a pic or video, but whirring sound on steering could be PS pump. If you have fiddled with the PS pipes and not secured them properly they make a nice metallic clunk when hitting the subframe. Quote Link to comment Share on other sites More sharing options...
mk2 Posted November 6, 2018 Report Share Posted November 6, 2018 I wouldn't drive it till you find the source of it. Clunks are usually serious. Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 6, 2018 Author Report Share Posted November 6, 2018 Changed ball joint for good measure but didn’t really do anything. Ah well, one less out of the collection! Top mount & bearing will be here tomorrow. I am hopeful that you’re going to be the winner of this one @mk2. FE264B37-0313-44BF-8380-D86E3A7BE611.MOV Quote Link to comment Share on other sites More sharing options...
cj1 Posted November 14, 2018 Author Report Share Posted November 14, 2018 Ok, changed top mount bearing and also discovered the front bolt of the suspension arm was slightly loose contributing to the banging. Still getting an odd noise on lots of turning to the right, suspect maybe tyre is catching on the spring as I noticed some rubber shavings on the strut and spring. The noise has only been present since I got the camber set to -1.5 deg, so ordered some 3mm spacers to move the wheels outwards slightly. Quote Link to comment Share on other sites More sharing options...
