BolaRosa
Heater air actuator
Hi,
my heater actuator has packed in... only got cold air! Has anyone changed this or know the procedures? Can’t find anything on it and don’t feel like pulling the dash unless necessary! Either that or a bodge for the winter so it blows hot air?
No quick fix. You'll need to get down behind the lower dash to see if the cable has jumped off the control knob to the hot/cold air diverter flap, or if there's a problem with the flap itself. Once you're in there give everything a clean and lube everything with dry lube spray. Everything will work really well afterwards.
