Steering making strange noise when I turn Steering wheel
Pete0309
54 Plate Lupo
When I turn the steering wheel there is a strange noise, almost like sand between 2 glass plates, or as if there is grit in there.  Does anyone know what this is and how much to repair (or how to repair!)  Will the steering give out eventually if I don't get it fixed in time?
11 hours ago, Pete0309 said:
54 Plate Lupo
Assuming its power steering, check the fluid levels are correct, waxoyl the power steering pipework regularly, not much to go wrong really as the most common issue is a split pipe
