dirk1978 Posted July 15, 2018 Report Share Posted July 15, 2018 Hey all. Really confused by what's happened here. I'm trying to repair my indicators and was taking the airbag off but left it balanced without disconnecting. It fell and pulled the connector apart. Doesn't look like it's damaged the airbag but I've no idea what this red wire is. It was just about attached to one of the 2 pins on the connecting ribbon cable but has now fallen off. Any ideas? Quote Link to comment Share on other sites More sharing options...
mk2 Posted July 15, 2018 Report Share Posted July 15, 2018 looks like you've broken the plug to start with. you'll need to replace that section back to the plug on the side of the steering column. no idea where that wire's from tho... Quote Link to comment Share on other sites More sharing options...
Rich Posted July 15, 2018 Report Share Posted July 15, 2018 new slip ring. i have been here before, crappy plugs. Quote Link to comment Share on other sites More sharing options...
dirk1978 Posted July 15, 2018 Author Report Share Posted July 15, 2018 This is how it looks like the plug should go back together. Which doesn't make sense. But it's the only way?? Is the slip ring the whole connecting ring behind the wheel? Quote Link to comment Share on other sites More sharing options...
Rich Posted July 15, 2018 Report Share Posted July 15, 2018 looks it. Quote Link to comment Share on other sites More sharing options...
