Lupse Lady
Lupo 3L TDI loses throttle response
Hi,
New here and not found any like issues when searching this site. Apologies if this has been discussed before.
My problem is that after I have driven a few km, the throttle loses response completely. I have to stop and restart after which it drives a km or so and then the same happens. This problem started a couple of days ago. My drive home from the shops took me 5-6 restarts. It does not seem to be at any specific speed as it has cut out both in 80km and 40km  speed zones. I hope someone can give me pointers to what might be the problem.
Thanks from Lupse Lady
Edited by Lupse Lady
fuel starvation.
check fuel filters.
good first place to start.
then 109, usual pattern.
Do you mean it goes to limp mode (gutless) or has no pedal input and only idles? Fault codes?
Is it an actual engine cut out?
@Lupse Lady which country are you in? we have some members on here all over europe (world!) who might be able to help you near where you live... :)
Check the hydraulic fluid level first. Top up with G004000 if required, even half a teaspoon can make a difference.
This should fix it.
