Michelle Posted June 9, 2018 Report Share Posted June 9, 2018 (edited) Hi guys, bought a lupo and everything's fine except for the main beam and dip beam, side lights work but main beam won't.. I've changed fuses bought new headlights and bought a new switch but still no main beam any suggestions please would be great.. Thank you Edited June 9, 2018 by Michelle Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 9, 2018 Report Share Posted June 9, 2018 possibly the wiring near the bulbs, or maybe the high/low beam selector switch on the indicator stalk. @Rich, what d'ya think? or @Skezza, ideas? oh, and a very warm welcome to the forum! Quote Link to comment Share on other sites More sharing options...
mattarosa Posted June 9, 2018 Report Share Posted June 9, 2018 id suggest its the stalk. Welcome Quote Link to comment Share on other sites More sharing options...
Rich Posted June 9, 2018 Report Share Posted June 9, 2018 if you're near me i will have a look. wiggle the earth cable inside the light, that fixed a mk4 for me the other week. Quote Link to comment Share on other sites More sharing options...
Michelle Posted June 9, 2018 Author Report Share Posted June 9, 2018 Would my indicators still work if this was broken many thanks to all replies Quote Link to comment Share on other sites More sharing options...
Rich Posted June 9, 2018 Report Share Posted June 9, 2018 completely different system within so I would presume they would. Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 9, 2018 Report Share Posted June 9, 2018 can you operate the flash function? pull stalk towards you... that bit bypasses the main circuit. also, it is both that are not working? there may be a relay in the circuit- i can't remember... which model lupo do you have? Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 10, 2018 Report Share Posted June 10, 2018 Like Matt said, could well be the stalk. They do fail occasionally and it's an easy part to test. When you say you've replaced the switch, an eBay job or an OEM one? Was the one you replaced an eBay one or an OEM one? (You can tell fairly easily). Check for corrosion around the battery terminals as well. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 10, 2018 Report Share Posted June 10, 2018 stalk wouldn't fail main and dipped. Quote Link to comment Share on other sites More sharing options...
Michelle Posted June 10, 2018 Author Report Share Posted June 10, 2018 (edited) I've swapped the switch from another lupo that worked fine just the side lights still work tho, I've found where the relays are il check them soon, the lights won't flash when I pull the stalk back, I'm so confused and clearly know nothing lol. Edited June 10, 2018 by Michelle Quote Link to comment Share on other sites More sharing options...
Rich Posted June 10, 2018 Report Share Posted June 10, 2018 there's some 53 relays which are load reducing but they don't really fail. I'd be inclined to look towards the 12v feed from the switch to the lights. common melting point on older vw. Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 10, 2018 Report Share Posted June 10, 2018 (edited) yeah, i'll second that. if both high and low are dead, it's probably the main feed. but the same is true if the bulb earth is dead. but you said the sidelights are ok (on the same earth wire i think), which should rule out an earth fault. does the little blue led light up in the dash when you flash? just thought... if a tracker has ever been fitted, the usual spot is behind the light switch. some bodgers completely mess up the 12v feed and it falls off! Edited June 10, 2018 by mk2 Quote Link to comment Share on other sites More sharing options...
Rich Posted June 10, 2018 Report Share Posted June 10, 2018 yeah, I ripped a black box out of mine the other week and it was on the headlight loom. Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 11, 2018 Report Share Posted June 11, 2018 23 hours ago, mk2 said: yeah, i'll second that. if both high and low are dead, it's probably the main feed. but the same is true if the bulb earth is dead. but you said the sidelights are ok (on the same earth wire i think), which should rule out an earth fault. does the little blue led light up in the dash when you flash? just thought... if a tracker has ever been fitted, the usual spot is behind the light switch. some bodgers completely mess up the 12v feed and it falls off! That ratty Mazda they fitted the black box behind the radio and made a pigs ear of it. Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 11, 2018 Report Share Posted June 11, 2018 yeah, and if you offer to wire it properly, they say it's not a valid installation. hmm. i didn't go to school to learn how to do it properly for nothing! Quote Link to comment Share on other sites More sharing options...
Michelle Posted June 11, 2018 Author Report Share Posted June 11, 2018 Thank you so much guys it turned out to be the stalk thanks for all your help Quote Link to comment Share on other sites More sharing options...
Skezza Posted June 12, 2018 Report Share Posted June 12, 2018 17 hours ago, mk2 said: yeah, and if you offer to wire it properly, they say it's not a valid installation. hmm. i didn't go to school to learn how to do it properly for nothing! I just ripped it out. It was the previous owners insurance, not mine. I Just wasn't overly impressed how they went about it. Quote Link to comment Share on other sites More sharing options...
