Camdeshifr33 Posted June 8, 2018 Report Share Posted June 8, 2018 Hi there just bought a lupo 1.4 and it's overheating temp light flashing and steam coming from header tank Quote Link to comment Share on other sites More sharing options...
Rich Posted June 8, 2018 Report Share Posted June 8, 2018 stuck thermostat. Quote Link to comment Share on other sites More sharing options...
Camdeshifr33 Posted June 8, 2018 Author Report Share Posted June 8, 2018 Easy to change? Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 8, 2018 Report Share Posted June 8, 2018 easy is relative. but yeah... Quote Link to comment Share on other sites More sharing options...
Camdeshifr33 Posted June 8, 2018 Author Report Share Posted June 8, 2018 5 minutes ago, mk2 said: easy is relative. but yeah... Quote Link to comment Share on other sites More sharing options...
Rich Posted June 8, 2018 Report Share Posted June 8, 2018 Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 9, 2018 Report Share Posted June 9, 2018 does the radiator fan come on when hot? could also be a duff thermostat fan switch. overheats when moving or when stationary, or both? if only when stationary, then most likely thermostat fan switch. if both, then coolant thermostat. or could be something much worse like head gasket or cracked head, but unlikely. is also possibly plastic water pump impellor has sheared off inside the pump housing (does happen). as the engine warms up, you can feel the hoses. if the thermostat is stuck closed, the hot water wont make it to the radiator which will stay coolish or only slightly warm. if fan switch, the rad will be roasting. dont open coolant filler cap when hot! like rich says- you can see the coolant surface moving inside the header tank if pump is ok. quick diagnosis without doing any work at all! Quote Link to comment Share on other sites More sharing options...
Sausage Posted June 9, 2018 Report Share Posted June 9, 2018 Yeah use a rag on filler cap as well, i got scalded at roadside when i was 18 despite opening cap carefully. Quote Link to comment Share on other sites More sharing options...
