lupo_crush Posted June 6, 2018 Report Share Posted June 6, 2018 VW LUPO 1.7 SDI 2001 I am looking for some help getting my trusty steed back on the road. Monday my power steering pipe split spraying fluid all over my drive. If Mondays are not bad enough already. I am struggling to find the part online or with a breakers. Dose anyone have any? Or knowlage on how to get it back on the road? Or is willing to help me? (Wiltshire area) I don’t really want to give up on it just yet. Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 6, 2018 Report Share Posted June 6, 2018 if you can get it out in one piece, take it to your nearest pirtek or hydraulic hose service place. they'll fix it for maybe a tenner and a six pack of cold ale. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 6, 2018 Report Share Posted June 6, 2018 yup. Quote Link to comment Share on other sites More sharing options...
lupo_crush Posted June 6, 2018 Author Report Share Posted June 6, 2018 50 minutes ago, Rich said: yup. 1 hour ago, mk2 said: if you can get it out in one piece, take it to your nearest pirtek or hydraulic hose service place. they'll fix it for maybe a tenner and a six pack of cold ale. Thanks, have you both used pirtek before? Would they make a set of hoses for it? Is this the only option? Anyone in the Salisbury area that could help me out? Quote Link to comment Share on other sites More sharing options...
lupo_crush Posted June 6, 2018 Author Report Share Posted June 6, 2018 Quote Link to comment Share on other sites More sharing options...
lupo_crush Posted June 15, 2018 Author Report Share Posted June 15, 2018 Refurbished powesteering line. £60 from pirtek. Cracking job. Even put a joint in for me after the flexi hose part to make to easy to fit back in with no problems. Gave it a quick service at the same time new oil and filters. 35% off at Euro car parts helped out. Quote Link to comment Share on other sites More sharing options...
Rich Posted June 15, 2018 Report Share Posted June 15, 2018 easiest solution. well done for listening. Quote Link to comment Share on other sites More sharing options...
mk2 Posted June 16, 2018 Report Share Posted June 16, 2018 nice result. that'll outlast the rest of the car! Quote Link to comment Share on other sites More sharing options...
Sausage Posted July 14, 2018 Report Share Posted July 14, 2018 Bottoms, mine is leaking on the TDI and they's very very rusty on the 1.4S as well. Pirtek in Swansea, but contacting someone else who seems to do very cheap hydraulic stuff. Will update when i hear back from them. Quote Link to comment Share on other sites More sharing options...
weslangdon Posted July 15, 2018 Report Share Posted July 15, 2018 I tried this on my Lupo TDI, whether it will work depends on where the replacement section is inserted, mine had split nearer to the connection and kept blowing off. I was lucky to get an as new replacement from a breakers yard as they aren't in stock anymore Quote Link to comment Share on other sites More sharing options...
Sausage Posted July 15, 2018 Report Share Posted July 15, 2018 I'll swap the pipe off the red tdi for now and then see about repairing the leaky one. petrol ones are different? Quote Link to comment Share on other sites More sharing options...
Rich Posted July 15, 2018 Report Share Posted July 15, 2018 the bottle is in a different place due to fuel filter. you could get away with a 6n one if you're lucky. Quote Link to comment Share on other sites More sharing options...
Sausage Posted July 26, 2018 Report Share Posted July 26, 2018 (edited) My pipe has a slow weep so not in immediate need of doing, but given that rusty and leaking steering hoses are now fails on MOT these will need doing. I've been looking for a cheap solution for the high pressure pipe between pump and rack, the others can be bodged with any oil resistant stuff and jubilee clips etc. I have looked into all combos of threads and adaptors even went looking at the an6 stuff but cost effectiveness and something well under the burst limit meant hydraulic pipe in the end. went for 1/4 bsp as it is 14mm O.D and pretty fexible. So got these: (prices are approx) 1 x m14x1.5 - 1/4bspp adaptor (for the rack) £2 1 x M16x1.5 - 1/4bspp adapter (for the pump) £2 1 x 1.25M 1/4 bsp hydraulic hose with 90 degree and straight end £10 for short run option. 1 x 2.5M 1/4 bsp hydraulic hose with 90 degree and straight end £14 for a more standard run option. Also need M16 copper washer £1 (i made one), M14 copper washer £1, or take one from the banjo fitting you remove. I also used an old bike inner tube as a rub sheath. So approx total price = £15 for the short run or about £20 for the longer run. Bspp = parallel thread. Adaptor in, I used the M14 copper washer from the banjo connector. I dont think anything will foul this connector, but until i try it on my car i wont know for sure. Obviously easier to just buy a M16 washer. M16 adaptor bottoms out in pump so needs a couple of mm ground off as you want it snug on the copper washer. The standard long run option will need to go up to clear exhaust and turbo and probably need some heat wrap. Will update when i get around to doing it, but so far the short run option looks promising. Edited July 26, 2018 by Sausage Quote Link to comment Share on other sites More sharing options...
mk2 Posted July 26, 2018 Report Share Posted July 26, 2018 Nice. I've got mine out at the mo too. Engine swap. Getting the pressure line off the power steering pump was fun... mine are slightly weepy, but not wet. I've figured out that you could reuse the old pipes, simply by cutting off the swaged joins. Then off to pirtek or someone to renew the flexi bits i reckon. Oh, and an audi 80 clutch plate fits nice! Back in tomorrow. Quote Link to comment Share on other sites More sharing options...
weslangdon Posted July 26, 2018 Report Share Posted July 26, 2018 Doesn't always work though, I tried replacing a section of a TDI's pipework with Pirtek's rubber hose but it blew off twice, so I ended up trawling ebay for a good 2nd hand one. No choice as they aren't made any more Quote Link to comment Share on other sites More sharing options...
weslangdon Posted July 26, 2018 Report Share Posted July 26, 2018 On 7/15/2018 at 4:46 PM, Sausage said: I'll swap the pipe off the red tdi for now and then see about repairing the leaky one. petrol ones are different? yes they won't fit Quote Link to comment Share on other sites More sharing options...
Sausage Posted July 26, 2018 Report Share Posted July 26, 2018 Yeah I was looking for a cheap way of fixing it for about £30 or less and seem to have come good on that front. If you add a 2nd bend 90 45 etc on the other end of the hose they need to know orientation to the 1st one, so i opted for straight connector instead, you can get swivel connectors but then the price goes up quite a bit, you could also split the long run into 2 hoses with a 90 degree swept joint in the middle but again price would double. Also on the petrol cars the exhaust wont be such an issue. Will bung on the short hose soon and then look into repairing my original one. Quote Link to comment Share on other sites More sharing options...
LR5V Posted July 27, 2018 Report Share Posted July 27, 2018 Nice cheap fix Sausage - where did you source your stuff from? I'm looking to try deleting the power steering and fit a loop of hose onto the rack, but I keep getting distracted by AN fittings on Ebay, your stuff looks spot on for my job aswell Quote Link to comment Share on other sites More sharing options...
Sausage Posted July 27, 2018 Report Share Posted July 27, 2018 https://www.ebay.co.uk/itm/Flowfit-1-4-Hydraulic-Hose-with-BSPP-Fittings-2-Wire-100R2AT-5880-PSI/252563577452 https://www.ebay.co.uk/itm/Male-Male-Hydraulic-Adaptor-Metric-Male-x-BSPP-Male-60-Cone/142826134109 I'm not sure if the narrow bore on the 1/4 bsp hose will be an issue or not, 3/8 bsp is next size up but will be stiffer and you'd need the 3/8 bsp adapters instead of the 1/4 ones i used obviously. You can get compact 90 bends, swivel joints etc but i just went for the simplest options to link the pump to the rack for now and will work out the details if things need changing later on. Quote Link to comment Share on other sites More sharing options...
LR5V Posted July 28, 2018 Report Share Posted July 28, 2018 Cheers Sausage - with your links I put together a 3/8 kit with 90 elbows for £15 if it turns out to be rubbish I wont feel so bad having spent so little, - well at least that's what I will be telling myself whilst re-installing the PS pipes Quote Link to comment Share on other sites More sharing options...
LR5V Posted July 31, 2018 Report Share Posted July 31, 2018 Got the hose today - glad I went for the 500mm one, 250 would have been too tight - what a lot of literature they sent with it Quote Link to comment Share on other sites More sharing options...
Sausage Posted July 31, 2018 Report Share Posted July 31, 2018 Did you get 1/4 hose with 3/8 ends on it or 3/8 hose with 3/8 ends on it? can i have some dimensions of the 3/8 ends (and hose is you got that)? The factory pipe has approx 5mm ID and all the fittings are about that as well. The 1/4 bsp hose is 6mm ID which is why i chose it but the 1/4 fittings are about 3.5mm ID so may put a bit more strain on the pump, they may well be fine though but I think 3/8 fittings is the way to go. Cheers Quote Link to comment Share on other sites More sharing options...
Sausage Posted August 1, 2018 Report Share Posted August 1, 2018 (edited) Plenty of room... Works fine. Very slight chatter at the wheel holding some lock or turning on the spot but i had over filled the reservoir. Hose doesnt chatter when holding it with someone else turning the wheel like i thought it might, so 3/8 fittings may solve that, but for now this is a cheap fix for rusty / leaking PS pressure hose, will buy the 3/8 kit and try that as well. Edited August 1, 2018 by Sausage Quote Link to comment Share on other sites More sharing options...
LR5V Posted August 1, 2018 Report Share Posted August 1, 2018 I went 3/8th... but remember I am deleting my power steering, the pipe is a vent to link the 2 connections up. Basically I am doing a DIY version of: https://eaaengineering.com/products/mk4-golfjetta-gas-diesel-bew-de-power-steering-conversion Granted its not as pretty, but all in a lot less cost than the $89 + postage from trumpville and then HMRC taking a chunk as well If I don't like manual I can put it back - will try it in stages, initially drained system for some mixed driving, then its either hoses back on or hoses, pump & reservoir stripped. Just got to source a shorter belt to drive just the alternator, that size is listed in another thread somewhere buried on here. Quote Link to comment Share on other sites More sharing options...
Sausage Posted August 1, 2018 Report Share Posted August 1, 2018 (edited) if the kit is still to hand and not on the car can you let me know the ID of the 3/8 fittings, i'm guessing it is up near 6mm. I'll redo mine in 3/8 fittings anyway as i have a couple of lupos to sort out. £5 for the adapters, £12 for the hose. Edited August 1, 2018 by Sausage Quote Link to comment Share on other sites More sharing options...
