Engine swap wiring
Rubbadub
Can any body help me out please, I'm doing an engine swap (1.8t beetle engine AWU code with me7.5 ecu)
Into a 1.0 lupo (with 7.5.10 ecu)
Does any body know where I can get a full wiring diagram for both cars/ecu?
I've got the power, ground, k line etc.  And there all the same but I need to work out how many of the other wires need swapping. If anyone could help me to find detailed diagrams or even shed a little light I would be really grateful
Regards
Dan
step one. are you up to getting the AWU engine running outside the car? you don't need to of course, but if you can do that the rest should be easy... make a dummy test stand, see if you can get the engine running on that. when you can (properly), then you can start to strip the lupo out. easiest/quickest way I've always found. wiring diagrams all over the interweb... :)
Cheers for the reply I've got it running in the beetle, ready to remove any time now, I'm assuming with immobiliser removed I could wire up the ecu to engine then add power and grounds where necessary for it to run? It's all the extra wires for sensors etc I can't find diagrams of, I'm goner have to buy a copy of elsawin or autodata I think as the awu doesn't seem to show any info for
Regards
Dan
